Tech Talk => Engine Mechanical / Electrical => Topic started by: Horizonjet on April 30, 2011, 10:43:15 PM
Title: 454 Build Stupid question
Post by: Horizonjet on April 30, 2011, 10:43:15 PM
I have rebuilt a 454, bored 30 over and new cam and my question is, I am getting ready to stab back into boat and i was running the oul pump with a drill to pressureize oil system and to makwe sure I am getting oil everywhere.  I have the valve covers off and I am not getting any oil up through the push rods and onto the lifters.  Is this normal???? I am getting oil in the filter and to the oil pressure sending unit and up in the valley under the intake... I would like to know before I put in boat and start and destroy it?  I konw it is a stupid question but I have never done this part of a rebuild before.
Title: Re: 454 Build Stupid question
Post by: IRRebel on May 01, 2011, 01:07:50 AM
Keep running yer drill until it does. Takes awhile to get the lifters bled. Last time I did it on a chebbie was with Tdawg and I think it took somewhere quite north of a half an hour with a drill to get ALL the lifters pumped up  :beer:
Post by: obnoxious001 on May 01, 2011, 01:48:33 AM
It's actually a very intelligent question, not many people prime their engines so carefully.
Every few minutes while the drill is running,, turn the engine over 90 degrees.  Are you running a hydraulic cam?
Post by: Horizonjet on May 01, 2011, 08:34:05 AM
Yes. It is a hydrolic cam and I never thought of turning it over every so often.  I just dont want to put it in  and have to pull it back out. Thanks for the info and I will let you know what happens later.   :)
Post by: Nordie on May 01, 2011, 10:44:49 AM
Horizon make sure you are running a zddp additive for cam break in! Would hate to see you have to do it again!
Post by: GlassCutter on May 01, 2011, 12:01:06 PM
Go to Home Depot and rent a drill.   >:D     It can't be good for them.     Or borrow one from someone you don't like very much.
Post by: Horizonjet on May 01, 2011, 12:52:00 PM
That is funny cause I left mine at work and my obnoxious neighbor was outside and I asked to borrow his. Let me say by the time I was done it was almost to hot to hold on to and had a funny smell and makes a noise now, hehehe.  After about a half hour and turning crank 90 degrees every once in a while I started to get the oil up through the push rods.  Hope to have the motor in next week and thanx for the advise. I will post picks of progress cause I konw how everyone like pics including me.  Why read when you can look at pictures.   ;D
Post by: Horizonjet on May 01, 2011, 01:53:12 PM
What spark plugs does everyone run. I personaaly prefur AC Delco but the dumb asses ant o riely gave me r44t adn they dont even screw in.
Post by: Nordie on May 01, 2011, 02:48:23 PM
I run accel shorty header plugs mainly because thats all i could get with the proper thread length
Post by: YumaJet on May 01, 2011, 04:54:23 PM
i just switched to autolite #23 gapped @ .35mm, im using an msd box too.
Post by: Nordie on May 01, 2011, 05:10:32 PM
Yuma! Is that a shorty reach plug? Meaning the. 750 thread length?
Post by: pw_Tony on May 01, 2011, 09:48:14 PM
Are you using the oil pressure primer fixture, that replaces the distributor? Or just a drill bit
Post by: Horizonjet on May 01, 2011, 10:11:47 PM
Just a drill bit, well a long flathead screw driver with the handle taken off and put into the drill.  I need the longer ones cause the short thread on the Delco pl;ugs wont even start
Post by: Nixonnow on May 01, 2011, 10:20:07 PM
i have the ac-delco r43t plugs in my 454. havent run the boat enough to prefer any kind of spark plugs. but just saying what im running.
Post by: obnoxious001 on May 01, 2011, 10:29:04 PM
If you are not using a regular priming tool that seals the oil galleys, not sure how you could get any oil to the pushrod?
When you buy spark plugs for a boat engine,, you basically need to go to the parts store knowing what you want,, all they can usually do there is look up by year and model.  You didn't give them the number of your old plugs, or take one with you?
 I normally buy plugs one or two heat ranges colder than stock "street" plugs,, since a boat engine gets run harder.  Personally I use Autolite or NGK plugs.
Post by: 81galaxy on May 02, 2011, 05:01:05 PM
as far as spark plugs it Depends on the year of the cylinder heads. Early heads take a long 3/4" reach plug and later heads use a short .460" reach with a tapered seat. I use r5673-7 ngks in my stuff for the later heads or an 8 with some compression or bottle. The early heads i use a b7es or b8es long reach. Also started using autolite racing ar3933 on the long reach stuff with good luck also. The autolite is a smaller 5/8 socket long reach plug. about a 1/4 inch shorter than the ngks. Also you can make an oil pump primer out of an old distributor that works quite well.
just my .02
Tom
Post by: Nordie on May 02, 2011, 06:18:45 PM
just my .02
Tom
i stand corrected my 990's run .460 reach  :banghead:
Post by: Horizonjet on May 02, 2011, 10:15:47 PM
Thanks for all the info. everyone.  I had to go get the longer rech plugs cause I am running 70 Chevelle heads. I got the Delco r44xls.
Post by: Nordie on May 03, 2011, 05:51:18 AM
If they are 70 chevelle heads that means closed chamber rect port....badass set of heads!
Post by: Horizonjet on May 03, 2011, 06:05:07 AM
Cool. I have not had any experiance with BBC, I was a small block fan so I am learning a lot.  The numbers stamped on the heads say they are for a 396 and with the decent cam I got sounds good. I can t wait to start it up.
Post by: TIMINATOR on May 04, 2011, 08:33:18 AM
Call me if you need help or questions answered. I am in the west Phoenix area.  623-877-8553  TIMINATOR
Post by: Nordie on May 04, 2011, 03:57:01 PM
definately not ls6 heads then! they are probably open chamber heads...
