Tech Talk => Engine Mechanical / Electrical => Topic started by: jamiemwedmore1234 on July 01, 2015, 09:23:30 PM
Title: Alternator issues
Post by: jamiemwedmore1234 on July 01, 2015, 09:23:30 PM
Help!!!! A buddy's boat that we just put the motor back in pump rebuild   And got it all wired up just like it was to begin with and the motor once started would not shut off with the key narrowed it dwn to the alternator back feeding the ignition ,',,,,what to do its a Motorola has 2 wires one to the battery and one to the ignition is there something I can put inline on the ignition wire or just replace the alternator thanks for any help
Sent from my iPad using SoCal Jet Boats
Title: Re: Alternator issues
Post by: carrera202 on July 01, 2015, 09:31:05 PM
I can stand corrected but I believe there needs to be a resistor installed for those if not is it a hei? If so check the batt wire make sure it on the ignition side not on a constant feed
Post by: philofab on July 01, 2015, 09:44:12 PM
Some alternators need to have a diode to keep back feeding or be hooked into their own leg of the ignition switch to work correctly.
Most auto parts stores should have diodes available for this.
Post by: jamiemwedmore1234 on July 01, 2015, 09:51:40 PM
The boat ran 2 days prior to this just pulled the motor and put it back do yo think something in the alternator broke would the quick fix be to just add a diode
Post by: philofab on July 01, 2015, 10:09:41 PM
You probably have a wire connected to the wrong spot on the terminal bar.
How many wires on your alt? Large gauge charge plus 1 or 2 small?
Post by: jamiemwedmore1234 on July 02, 2015, 04:29:09 AM
1large gauge 1 small gauge. Double checked the wireing even pulled all the wire loom apart and traced down the wires
Post by: philofab on July 02, 2015, 08:47:37 AM
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.jamestowndistributors.com%2Fuserportal%2Fwoeimages%2Fhowtos%2F1096a.jpg&hash=fe787452de8db7b5e27abe00114ad9c79d2dc60b)
Does this look like your alt?
Post by: jamiemwedmore1234 on July 02, 2015, 10:09:51 AM
No I'll pull up the pic of the one I have
Post by: jamiemwedmore1234 on July 02, 2015, 10:12:00 AM
This one
