Tech Talk => Engine Mechanical / Electrical => Topic started by: FORKEDUP on January 09, 2008, 03:22:43 PM
Title: alternator mounting
Post by: FORKEDUP on January 09, 2008, 03:22:43 PM
i need some help/input with mounting my alternator, i have never run one before so i do not have any brackets, all the mounts i have looked at want to mount the alternator right where my motor plate is or way up high by the valve cover (up high is not an option, doesn't look right), i don't think there is enough room in the tunnel to put it low, by the oil pan, does somebody make a stringer mount??, any pics or ideas would be appreciated, here are a couple pics of what i am dealing with, i will try to get some better ones tonight,    thanks in advance, bill
Title: Re: alternator mounting
Post by: CHROMEY on January 09, 2008, 03:51:15 PM
here is a pic of my buddys boat we mounted it off the head and dosnt look too bad.....
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10582%2F002.jpg&hash=d73825710e9657a60b404829afa33881e6ee380c)
oh....wanna race?
Post by: pw_Tony on January 09, 2008, 03:57:55 PM
I've seen some trick direct drive alternators, I think it was on Brendella Jet's brendella. I've been having a hell of a time keeping my belt on, and no one seems to sell marine alternator brackets, at least not for a ford
Post by: FORKEDUP on January 09, 2008, 04:16:56 PM
oh....wanna race?
i'll race anything on the water, i don't care what the hell it is or how fast you think it is!!!!!!!!!!
as long as it doesn't go over 50mph ;D ;D ;D
and i get a head start ;D
Post by: CHROMEY on January 09, 2008, 04:24:15 PM
sure why not.....head start will be fine, i sleep @ the light anyway ;D
ill try to get over there this weekend and take some closer pics, or at least find out what brackets he has!
Post by: Jetaholic on January 09, 2008, 06:29:27 PM
Mine was made by ironman44bear. He made a pivot bracket out of 6061 aluminum and we bolted that to a piece of angle aluminum mounted to the outside of the starboard stringer. He slotted the mounting bolt holes to make it adjustable front and rear for proper belt alignment with the crank pulley.
He then made a turn buckle that spans from the alternator to the cylinder head to make belt tension adjustment a breeze.
Post by: FORKEDUP on January 09, 2008, 07:16:35 PM
chromey, some pics would be great, and as far as racing him, i think he is probably over the 50mph clause ;D
jet-if you could get a pic of your set up for me it would help alot, i have a friend that can fab alot of shit up, i just need to bring him and idea of what i want.
i got a couple more pics tonight of what i am working with
thanks for the help guys ;D ;D
Post by: Oldsquirt on January 09, 2008, 08:56:02 PM
ForkedUp, the hole on the right side of your motor plate was intended to be the alternator pivot. You will have more room for the alt on that side as the exhaust on that side sits an inch or two further back. You might even consider using one of the mini- or ultra-mini alternators to help with the fit issue. It is nice to see you have a marine-equipped version of the GM 10SI alternator, though.
Post by: crewchief22 on January 10, 2008, 07:19:47 AM
If you don't plan on running a radio, you can get away without the alternator.  Just be sure to get a good deep cycle battery and charge it every time you get home.
Powermaster shows a spacer kit for a low mount alternator with a motorplate, if you have room.
http://www.powermastermotorsports.com/racing_accessories.html
Post by: Jetaholic on January 10, 2008, 07:44:34 AM
True...however, there's absolutely no reason not to run an alternator.
Post by: FORKEDUP on January 10, 2008, 09:29:36 AM
oldsquirt, i always thought that hole was incase a mechanical fuel pump is run (clearance)??
thanks for the link crew, i think i can make some spacers like that and probably get it to work, i might go to the right side though like oldsquirt said, so i don't have to make them as long, i will not be running a radio, as i have said i have never run an alternator before and only had a problem one time, after that i swore never again and the father in law hooked me up with a free alternator so why not...  went to lake pleasant here in phoenix right before boat was taken apart for paint, went to the back cover where everyone parties, mostly rich kids in their big sleeks and magics, well they start swamping me pretty bad, bilges are running like crazy, try to start the boat to move and now it does not want to start, oh f***, houston we have a problem and alot of water on board, now my battery is dead (optima), luckily a nice fisherman had a jump box and a spare battery, hooked both up to my battery to get it to start (all 3 tunnels are full of water at this point and its up to the seats), get boat started and haul ass, the x-tra battery and jump box got me back to the dock, but screwed my floor in the process, since then i swore it would get an alternator when it went back together.
Post by: jet boat performance on January 10, 2008, 10:31:15 AM
Forked theres a couple of easy solutions eg fabricate brackets and mount the alt backwards or ,if room drive it off the crank  (kits are fairly reasonable) or call or post if you need other suggestions  Tom
Although I run my flat with no alt (two optimas bats) , MSD Electronic ignitions for example "like" a constant voltage of 13+ volts ,but will work as low as  9 and as high as  18 (i edited this to add a pic of a recent Alt mount we did as well photo 2)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi147.photobucket.com%2Falbums%2Fr319%2Fjetboatperformance%2Falt.jpg&hash=477bc57f2f5919a965057a2cacfaf1442f7c8272)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi147.photobucket.com%2Falbums%2Fr319%2Fjetboatperformance%2Ffrednbev200131.jpg&hash=9536809b4a1244c0e0610dff5d0cb6bcae6e622d)
Post by: VAMI on January 10, 2008, 01:28:59 PM
that hole on the plate is the pivot hole,cp has a top curved piece that bolts in the  threaded boss on the block and works perfect.
Post by: hotrod56cars on January 10, 2008, 01:34:25 PM
That usually only works if you're using the old style of mounts and not a rail kit. I don't think I've seen engine plates for a rail kit that have a provision to mount the alternator.
I had one of those "crank mounted" alternators in my Mach 1. Exactly the same as the purple one in the picture that Tom posted. I never did get it to work in my boat but a electrical shop told me it was good. ?  It looked pretty cool. For an alternator it took up a lot of interior room though. I sold it and bought a mini alternator that I'm going to try to use instead, that is if I ever get another engine in it.  :-[
Post by: Marcsrollin on January 10, 2008, 06:42:00 PM
If you change to a magnito , the battery is purley to start , not to run. And they look cool as hell.
Post by: Oldsquirt on January 10, 2008, 07:28:51 PM
I was referring to the small hole above and to the outside of the fuel pump "window".
Post by: Oldsquirt on January 10, 2008, 07:31:48 PM
That is EXACTLY what that particular hole in the front plate is for and CP's adjuster bracket should work perfectly.
Post by: FORKEDUP on January 12, 2008, 01:52:23 PM
thanks for all the help guys, i have not replied to this for a couple of days because i have not had a chance to get out into the garage to check something........... understand i have completely taken apart and reassembled this boat twice now by myself.  when everyone started talking about this hole in the mount i was like there is no hole there that is just a reflextion..i had to wait until i could get in the garage and actually check :(  with all the time i have spent on this f'n thing i have NEVER noticed that little fuking hole, its amazing how when i hold the alternator up to it everything lines up, should be a rather simple install.   thank you to everyone for the info and the lesson it was a tremendous help, i look forward to meeting all of you at the gathering ;D
Post by: hotrod56cars on January 12, 2008, 03:21:23 PM
Pic please.
Post by: FORKEDUP on January 19, 2008, 05:59:14 PM
ok alternator is mounted, now for the wire going to the starter, is 10ga wire enough or should i run a thicker wire, thanks again in advance---bill
i will get pics as soon as wires are run----will happen tonight ;D >:D
Post by: FORKEDUP on January 19, 2008, 07:00:13 PM
never mind, jetaholic answered it in the "wiring diagram" thread====thanks
Post by: hotrod56cars on January 19, 2008, 07:21:56 PM
Where's that at?
Post by: FORKEDUP on January 19, 2008, 07:29:46 PM
hope i do this right
http://www.socaljetboats.com/index.php?topic=2326.0
it was his article on a jet boat wiring harness, in it it is specified 16ga unless otherwise stated, alt is listed as 8ga
Post by: hotrod56cars on January 19, 2008, 08:22:19 PM
IMO
If you're using an extra starter solenoid, as in that wiring diagram shows an extra solenoid, then yes 16 ga is fine. However if you're using one starter solenoid, which any GM engine only uses one solenoid for the starter, then you're going to want to run a  thicker gauge wire.
GM cars and trucks use a 12 ga wire but their ignition switches are much closer to the starter than in a boat (as the wiring is usually run). If it's a GM engine and you're only using the solenoid that's on the starter I'd run at least 10 ga., probably 8 ga..
IMO
... i am not running an aux solenoid...
Post by: hotrod56cars on January 19, 2008, 08:25:08 PM
... I don't think I've seen engine plates for a rail kit that have a provision to mount the alternator...
I need pics man, I'm dieing over here, please, please...
How'd you mount that alternator?
HA HA HA   :D
Post by: hotrod56cars on January 19, 2008, 08:27:20 PM
HA HA HA   :D
Found it, thanks!!!
Post by: bkplesh on January 19, 2008, 09:37:09 PM
Rod, give it up! that boat doesnt have a motor in it! ;D
Post by: SLCKREG on January 20, 2008, 07:57:16 AM
Forked up what pic. I haven't  paid any atention to this thread until last night when I went to put my alternator on(new rail kit)  and whatta ya know , I've got the same problem. I'm having a hard time trying to figure out how that hole in front of the fuel pump is going to be the pivit point? Forked where is the pic? Maybe I sould try agin this morning(sober ::)I figured something like what Chromey posted but it would only have 1 bolt holding it to the head,I had a set up like that on my k boat and it was constantly loose. BTW I didn't know you could run an alternator backward. Jetaholic your mount is pretty slick also,If I didn't still have 50 things to do b-4 I hit the water I'd probably pursue something like that.
Post by: FORKEDUP on January 20, 2008, 08:17:43 AM
i put the pics in the project thread "it's home",porbably should have put them here first, the hole that they were refering to is the one above the mounting hole to the rail, my dumb ass thought they were talking about the fuel pump hole ;D, i believe you need to do something to the alternator before you run it backwards, hopefully someone will chime in on that because i am not sure, anyway here are the pics from last night, i still need to wire it, i only had 10ga at the house, so the wife is getting me 8ga this am/
Post by: SLCKREG on January 20, 2008, 09:48:05 AM
Thanks for the pics Forkedup. I'll go out there and scratch my head again. I think our rail kits are  different. The "hole " in front of where tha manual pump would be on mine is about the size of a silver dollar.
Post by: hotrod56cars on January 20, 2008, 09:52:37 AM
... i believe you need to do something to the alternator before you run it backwards, hopefully someone will chime in on that because i am not sure...
It's not running backwards, it's going the same direction as it would if it were bolted to the other side of the engine.  :D
My rail kit/engine plate doesn't have that hole.
Post by: SLCKREG on January 20, 2008, 10:44:33 AM
Tom put up a pic of an alternator with the pulley facing the back of the boat, I didn't know you could do that. I cant come up with anything that looks decent with the brackets I have, looks like it's back to the wallet. Time to call Tom.(monday)
Post by: HDriderTH on January 20, 2008, 10:49:30 AM
it doesnt matter which direction it runs. i've seen 'em on the rear end and just worked on a Willys w/ it on the motor plate backwards
Post by: Oldsquirt on January 20, 2008, 11:21:58 AM
Your front plate has the same alternator mounting hole as shown in FORKEDUP's pics. It's right at the top right hand corner of the plate. As mentioned before, we are not talking about the fuel pump "window".
Post by: SLCKREG on January 20, 2008, 03:03:48 PM
Umm oh that hole :o yeh I fell pretty stupid I'm glad that hole works better thatn the fuel pump window b-cause that one worked so good I'm now runnin an electric (or tryin to) Thanks for the tip on the upper bracket Vami, cp it is.
Post by: CHROMEY on January 24, 2008, 04:16:24 PM
ill put it in any hole  ;D just spit on it first and it should go in!!! lol >:D
