Tech Talk => Engine Mechanical / Electrical => Topic started by: randog on August 19, 2013, 09:15:27 PM
does any one or has any one ran this exhaust mine leak a little in the middle and i dont think i can find the right gasket for them so i dont want to pull it apart in tell i know what i can make a gasket out of any thoughts thanks
I will see if I can find the part number. I will be hone in about an hour and have the book.....
Gaskets are still available.
Thanks gt what do you think about these are they junk they look good and sound good there only held one by four bolts and no gaskets stright to the head and don't leak weird
Go get some gasket material at the auto
parts store and make your own. You can set it over the flange and tap around the edges with a ball pein hammer to score the pattern, or make a pattern out of a piece of paper rubbing a crayon over it to mark the flange.
Get a chunk of aluminum or something fairly flat, wrap some sandpaper around it and go at the flanges to make sure they're flat before putting it all together.
The gaskets should be changed annually. Those are great manifolds. Best bang for the buck and only just short of headers as far as performance.
Yeah that's cool there better than logs.there nice not getting burned on that's fore sure. And they buff out nice
That was what I planed on doing but it looked like they have a rubber gasket I'm them
There on a 460 Berkeley packajet I've only seen two other sets of these and for fords only where they a packajet 460 manifold only
