Tech Talk => Engine Mechanical / Electrical => Topic started by: GoinBrokeBahner on January 21, 2014, 07:47:36 PM
Title: BBC oil pan advice...
Post by: GoinBrokeBahner on January 21, 2014, 07:47:36 PM
I currently have an 8qt truck pan on my stock 454. I got this pan back in March when I had my motor rebuilt. The mechanic threw it on as a favor because he noticed my motor came with a stock capacity car style pan. The problem is the pan is a bottom drain and the very end of the drain plug head is touching the glass. I ran it for this last season just because it took so much to finally get on the water. Now I'd like to improve it and do a couple other things while motor is out. I don't believe I need a real expensive one but have learned thru this site that there are certain pick ups needed and windage trays, ect.....
I've found a few online and will post pics. I'm finding a lot more 6 and 7qt pans than 8qts. Should I focus on an 8 or is a 7qt good, possibly with using larger capacity filter? Also I've seen MANY different styles of trays inside these pans...?
Any help is much appreciated! Maybe one of you have the perfect used pan I can purchase.?.
Thanks!
Title: Re: BBC oil pan advice...
Post by: HardLuck Baker on January 21, 2014, 08:09:54 PM
I have the Milodon 10qt. marine oil pan, and they also have a pickup for that pan. They are a little pricey though. I know summit sells them
RoB~SoCalJetBoats~
Post by: GoinBrokeBahner on January 21, 2014, 08:12:06 PM
RoB~SoCalJetBoats~
Thanks for reply. I know those are pricey... Is a 10 qt a little over kill for my motor? Or is too much a good thing in this case?
Post by: HardLuck Baker on January 21, 2014, 08:17:42 PM
.  IMO I think more oil is good. I have a mild built 454 and as far as oil goes I've had no issues.
RoB~SoCalJetBoats~
Post by: HardLuck Baker on January 21, 2014, 08:22:01 PM
In the class 5 car that I've been helping with, we actually run an extra qt. of oil. Gotta figure most of the oil is on the top end when your running hard.
RoB~SoCalJetBoats~
Post by: GT Jets on January 21, 2014, 08:37:01 PM
I may be showing my redneckness here, but why not pull the pan, cut the spot-welds around the plug bung and relocate it to the side or the rear?
Be really cheap even if you had to pay someone to weld her up...
Normally the big pans hit the pump intake.
Just a thought.
Post by: GoinBrokeBahner on January 21, 2014, 08:37:20 PM
you can never have enough oil.
would something like this work for you?  8 in depth.  not terribly expensive.
http://www.ebay.com/itm/Chevy-BB-BBC-396-427-408-454-496-Gen-4-10Qt-Full-Sump-Orange-Oil-Pan-/131092885851?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e85beb15b (http://www.ebay.com/itm/Chevy-BB-BBC-396-427-408-454-496-Gen-4-10Qt-Full-Sump-Orange-Oil-Pan-/131092885851?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e85beb15b)
I think that would work great! I'm a little over 8 1/2" depth now with that bottom plug... Do I need different pick up and is there anything else needed?
Thanks for your other feedback too Baker.
Post by: HardLuck Baker on January 21, 2014, 08:37:22 PM
That would be perfect. And half the cost.
RoB~SoCalJetBoats~
Post by: 77Eliminator on January 21, 2014, 08:44:48 PM
This is the one that I bought last summer for my bbc. 11qt with baffles.
http://summitracing.com/parts/sum-g3607 (http://summitracing.com/parts/sum-g3607)
Post by: GoinBrokeBahner on January 21, 2014, 08:49:23 PM
Oh sh#t, check out shipping cost!!
Post by: GoinBrokeBahner on January 21, 2014, 08:50:36 PM
Thanks!
Post by: GT Jets on January 21, 2014, 08:53:11 PM
They sending that sombitch by limo? :screwy:
Post by: randog on January 21, 2014, 09:04:16 PM
Just a thought.
X2
Post by: Jet Boat Maloney on January 21, 2014, 09:24:49 PM
Just a thought.
That sounds like the best solution. That way there is no need for a new pick up and you can add another bung so you can run an oil temp sender. Also connect a drain/pump hose with a suction check valve and just pump the oil out. JMO
Post by: Beaveretriever on January 21, 2014, 09:34:58 PM
Hamburger pans makes a 10qt for around $250 a speed shop should be able to get you one and not pay $300 for shipping. Thats what my plan was until I found a deal on a stephs pan
Sent from my SAMSUNG-SGH-I747 using SoCal JetBoats mobile app
Post by: GoinBrokeBahner on January 22, 2014, 05:36:41 PM
Found a used Dooley 10qt pan w/pickup today for $150! Freshly hot tanked and ready to go. 👍🍻
Post by: GoinBrokeBahner on January 22, 2014, 06:04:49 PM
sweet!  when can i come pick it up?
Hahaha! $275, come get it! LOL
Thanks for the advice.
Post by: jamiemwedmore1234 on January 22, 2014, 06:31:59 PM
If your still looking for a pan I have the stock pan that came off my motor still drains in the rear but I have a plug with a hose that comes off it came off a bbc in a jet boat
Post by: GoinBrokeBahner on January 22, 2014, 06:59:32 PM
Scored one today but thanks anyway.
