Tech Talk => Engine Mechanical / Electrical => Topic started by: angermgmt on November 21, 2014, 02:09:24 PM
Title: BBF Block
Post by: angermgmt on November 21, 2014, 02:09:24 PM
Is this block usable?  Looks like a repair or casting blew.
Title: Re: BBF Block
Post by: angermgmt on November 21, 2014, 02:10:51 PM
Post by: angermgmt on November 21, 2014, 06:30:47 PM
Sorry with the typo. "Blem"
Post by: herrhauptman on November 22, 2014, 09:16:38 AM
It looks like some kind of a flaw along the bottom  of a cylinder bore.  It was most likely always there, and as long as it doesn't leak water or cause any other issues it will be fine.
Post by: angermgmt on November 22, 2014, 09:52:34 AM
That's what I was was betting on. Piston skirt doesn't touch that area. I took a risk on the purchase its a SCJ block. Going to be a retirement project in the near future.
Post by: bronco1 on November 24, 2014, 06:51:16 PM
The only time you might want to get it fixed is if plan on building a stroker motor
Post by: LakesOnly on November 26, 2014, 08:21:17 AM
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Findex.php%3Faction%3Ddlattach%3Btopic%3D22283.0%3Battach%3D129767%3Bimage&hash=67fae21440b714eb803431857d07464c93a9f332)
From the picture, the feature at the base of the cylinder looks like an everyday casting anomaly and nothing more.  It does reach upward toward the water jacket but if it doesn't leak or isn't too thin then it is of no concern whatsoever and the block is as good as the next, capable of supporting over a thousand horsepower.
Farther up the picture, there looks to be another anomalous feature: a casting void in the machined portion of the main web.  As long as that is negligible as well (ie, not to deep, etc) then that's a non-issue just the same.
In the majority of builds where this block would be used, those features may be left alone, meaning it's not even necessary to acknowledge their existence (in a build of extreme abusive power might I consider blending them out).
Post by: angermgmt on November 26, 2014, 10:48:44 AM
Thanks Paul appreciate your help. B
