Tech Talk => Engine Mechanical / Electrical => Topic started by: bbfsouthwind on October 04, 2010, 06:52:48 PM
Title: best bbf stroke length?
Post by: bbfsouthwind on October 04, 2010, 06:52:48 PM
I was looking at overlap drawings of crankshafts and noticed the 4.5" crank I was wanting to run has a very small overlap and seems kind of weak looking to me. If someone could shed some light on what would be the best compromise between stroke length and crankshaft strength. I want as many c.I. like anyone else but I don't want a crank that I am afraid of breaking when I put nitrous on the motor. I plan on making around 700hp n/a then some nitrous once everything is sorted out.
Title: Re: best bbf stroke length?
Post by: Ralph Brunt on October 04, 2010, 06:57:09 PM
what heads are you going to use and what kind of comp do you want
700hp is easy with a 4.150
Post by: bbfsouthwind on October 04, 2010, 07:12:37 PM
Ported dove heads and 10-10.5/1 ce. Will be running a custom camshaft, haven't decided weather to go solid roller or flat tapped solid. Cleaned up tunnel ram with 2 660 center squirters.
Post by: LakesOnly on October 06, 2010, 11:05:09 PM
Technically speaking, the less rod/main journal overlap the less stuctural integrity of the crankshaft, yes. But this does not mean in-and-of-itself that a crankshaft "isn't strong" per se....regardless of manufacturer and/or brand application. But...one may indeed deduce that a crankshaft with less journal overlap is likely not as strong as an equivalent crankshaft with more journal overlap.  That much is obvious.
Most offshore cast stroker cranks for the BBF that are 4.500 stroke are "rated" to 700+ hp. That being said, I have seen more broken crankshafts, more windowed cylinders, more burnt valves, more blown head gaskets, etc, from nitrous oxide than any other form of power adder. Therefore, if you want to have 700 hp + nitrous oxide then I would insist on a forged crankshaft,....I don't care how much or how little journal overlap there is.
Post by: bbfsouthwind on October 07, 2010, 07:06:33 AM
So let's say that I choose not to run nitrous down the road and I just upgrade cylinder heads later instead. Would a good cast scat crank fit the bill? 1k for a crank is a little out of my budget at the moment but I want a strong setup.
Post by: Ralph Brunt on October 07, 2010, 08:50:14 AM
yes
700hp with dove heads is a tall order in a jet boat
 lakes built a 521 (ithink) for dan hurcules and it makes over 700hp on pump gas but, it has good heads
Post by: LakesOnly on October 07, 2010, 10:08:45 AM
Yes, ported D0VE heads can get you to 700 hp, and the addition of better heads could get you more horsepower down the road.....but you will still be exceeding the rating of that cast 4.500 crankshaft when you add the better heads. They've been known to hold in excess of 700 hp but I won't recommend it.
1K ought to get you a brand name forged crankshaft, not just a cast one. And depending where you go you may have money left over.  If you're worried about spending $700-$900 on the crankshaft alone, then you probably shouldn't be looking at building a 700+ hp engine as a properly outfitted one can run you well into the 5 figures.  If you want just a 4.500 stroke shortblock that will hold well over 700 hp (onto which you can install your ported D0VE heads), you're still looking at several thousand.
Post by: Ralph Brunt on October 07, 2010, 10:12:15 AM
lakes, the amount of port work that is needed to get to 700 hp with the dove heads is a lot $$ wise dont you think ???
Post by: LakesOnly on October 07, 2010, 11:31:22 AM
Lol, it sure can be.  :)
Post by: bbfsouthwind on October 07, 2010, 04:03:00 PM
I have been thinking and I will just set aside 1k for the crank and balancing. There is no need to do this twice. I will be getting a 5 angle valve job cut on the heads and will be porting them myself the rest of the way. I bought brad's dove a heads a while back. I think that the power I am asking for is reasonable. I build an iron head 347 smallblock Ford that ran on pump gas and made just under 525hp, and I know what I am really looking for here in this motor is torque. I just want my boat to run in the high 80s.
Post by: Marcsrollin on October 07, 2010, 04:36:55 PM
Port the heads before you do the valve job.
Post by: bbfsouthwind on October 07, 2010, 08:00:27 PM
That's some good power. What kind of camshaft and intake?
Post by: LakesOnly on October 07, 2010, 10:54:47 PM
On my next engine, I want to go forged 4.3 stroke and run P51 heads. I will give you a call Paul when I get ready to do that.
No prob.
Post by: LakesOnly on October 07, 2010, 11:03:17 PM
This depends on application, combination, etc.  Generally speaking, I reallly like the 4.3 stroke/6.8 rod combo for several reasons, including pin placemernt at BDC, rod ratio, power producing capabilities, etc. It's an "overall" winning combo and works great in a jet boat.
bbfsounthwind, are you aware that you cannot just purchase a crankshaft and re-use your 460 rods and pistons?  If you use a stroker crank, then you also need stroker-specific connecting rods and stroker-specific pistons.  Quality, brand name complete stroker kits (crank/rods/pistons/rings/bearings) run about $1699, and $400-$500 more for the 4340 forged crankshaft.  Then add the balancing, mallory metal, boring the block, etc.
Post by: bbfsouthwind on October 08, 2010, 03:36:33 PM
Yes l.o. I am completely aware, you must have just misunderstood me. Anyways.. how many cubes can you get out of a 4.3" stroke with a 6.8" rod? And I had planned on spending around 2k for my rotating assembly, give or take a few hundred. I want to stay at a .030 overbore or as close as possible.
Ps this isn't my first rodeo with stroker motors, just with a bbf. And I appreciate everyone's input, thank you.
Post by: Ralph Brunt on October 08, 2010, 05:46:54 PM
copied from 460ford.com
For(d) easy reference;(formula......Bore X Bore X Stroke X .7854 X 8 )
Stroke (in.) Bore (in.) Overbore (in.) Displacement (cu. in.)
3.590 4.360 stock 429
3.850 4.360 stock 460
3.850 4.390 0.030 466
3.850 4.400 0.040 468
3.850 4.420 0.060 473
3.850 4.440 0.080 477
4.140 4.360 stock 494
4.140 4.390 0.030 501
4.140 4.400 0.040 503
4.140 4.420 0.060 508
4.140 4.440 0.080 513
4.300 4.360 stock 514
4.300 4.390 0.030 521
4.300 4.400 0.040 523
4.300 4.420 0.060 528
4.300 4.440 0.080 533
4.500 4.360 stock 537
4.500 4.390 0.030 545
4.400 4.400 0.040 547
4.500 4.420 0.060 552
4.500 4.440 0.080 557
Post by: gordyd4 on October 09, 2010, 11:43:35 AM
I've had several BBf stroker motors.
The 4.3stk/6.800 rod technically is a great setup. Had this setup also.
The difference in strength between the 4.3&4.5" stroke is nill.
The last engine I built was an all aluminum 604cid.  I ran the crap out of that engine in a sand car. 4.500 stk x 4.625 bore  w/6.800 rod, 930hp.
Honestly even a cast crank would be fine. But for a few hundred dollars more, why not get the forged crank.
I am currently just starting a new BBF build. Boss hemi heads, 4.5"stroke w/6.800 rods.
I thought about doing the 4.3 stroke, but only for a millisecond.
-Gordon
Post by: gordyd4 on October 09, 2010, 12:57:30 PM
Shitcan the nitrous and the heads, and buy a set of aluminum heads.
Save the money from porting and the nitrous, and have a better all around engine longterm :)
Post by: bbfsouthwind on October 09, 2010, 02:55:05 PM
I'll be keeping my heads I have for now. I've already paid for them and the porting will be free. I just don't have room in the budget for alum heads   :-[X :P
Post by: bbfsouthwind on November 22, 2010, 04:30:23 PM
I am about to pull the trigger on the rotating assembly, I want the extra cubes from the 4.5" crank but I.don't want to sacrifice durability in the stock block with the long stroke. I.just need a good push either way 4.3 or 4.5
Post by: Marcsrollin on November 22, 2010, 05:18:38 PM
I went with the 4.500 and bored the block .030 over and ended up with a 545 cid. I could not be happier! Right now as it sits it is @ 11.23:1 compression and this winter I am going to 14:1. As it sits now I pull a detailed bronze B impellor to anywhere between 6300 to 6500 rpm. Make sure you get a dished piston or your compression will be through the roof!
Post by: bbfsouthwind on November 22, 2010, 05:39:18 PM
Will be running a 22cc dish probe piston for now until I switch to p-51 heads later down the road.
Post by: Marcsrollin on November 22, 2010, 06:27:21 PM
Same piston I was running! I am swapping them out for JE next week.
