Tech Talk => Engine Mechanical / Electrical => Topic started by: chaosmotox on September 22, 2014, 11:00:10 AM
Title: Carb ? Need help
Post by: chaosmotox on September 22, 2014, 11:00:10 AM
I have a stock Hardin Marine 454 with peanut heads. For a Holley 750 street avenger with vacuum sec and electric chock. Would this be a good carb to put on my boat. Any input would be nice.
Title: Re: Carb ? Need help
Post by: jyeager on September 22, 2014, 11:04:54 AM
750 or 850 is fine. I would go with manual secondary's. No choke 👍👍👍
Post by: Beaveretriever on September 22, 2014, 01:37:07 PM
I run a stock marine motor and a 750 is plenty big. I run vacuum secondaries on mine and it runs good. If the boat is going to be used for cruising and not hauling ass all the time vacuum secondaries are better on fuel. Mine has a 4010 Holley which is not a great carb but it sure runs good
Sent from my SAMSUNG-SGH-I747 using SoCal Jet Boats mobile app
Post by: chaosmotox on September 22, 2014, 01:48:16 PM
Well I was gonna buy the carb but found out the carb might not be the issue. The boat can't run past 4000 rpms and if I get it on it real quick it just stalls out. I was talking with someone at J&M and he thinks it my HEI dis. When I bought the boat it came with a procomp HEI and he thinks that's the issue. So I went ahead and bought the MSD HEI. Let's hope this fixes it.
Post by: jamminjetta on September 22, 2014, 03:36:15 PM
Mines all stock and only turns 4100 rpm. I've got the msd marine ignition
Sent from my iPad probably bored at work! Lol!
Post by: chaosmotox on September 22, 2014, 04:29:54 PM
What does your motor do after you hit 4100. Mine just craps out and sputters.
Post by: riverrat7777 on September 22, 2014, 05:09:40 PM
I run a stock 454 with a 4011-1 and a procomp hei and I can run 5100+
Post by: chaosmotox on September 22, 2014, 05:28:07 PM
Yea I wish mine ran like that.
Post by: riverrat7777 on September 22, 2014, 05:32:42 PM
whats your timing number without vac adv att at 3000 rpms
Post by: beerjet on September 22, 2014, 05:40:52 PM
X2
Post by: Your Mom on September 22, 2014, 08:49:16 PM
I ran a 750 vac secondary for years worked fine and now running a 850 mech with mild built motor.... way better on my cruiser and fuel is about the same. If carb is built right it will run right...
Post by: freshmeat on September 23, 2014, 06:21:27 AM
I have a stock 454 and mild cam, 750 edelbrock carb. Running an "A" cut impeller. I can only get about 4200 rpm.
