Tech Talk => Engine Mechanical / Electrical => Topic started by: More2LifeThanMPG on November 05, 2011, 08:51:38 AM
I took the carb off my motor and have gone to Autozone, O'reilys, and called Napa. None of them can pull up the kit for it. Where has anyone gotten there's before? (it's a holly 4 barrel) and the numbers on the "motorcraft" tag are D4JL-J-7F8
Sent while on the run, or sitting at work bored
If it is a Holley, then look on the choke housing for the LIST number
Is it like 6R-4920B...?
Jkjking... The there are three numbers, listed just like this.
D4JL-3510-J
LIST-7128
1597
The Holley web site shows the 3-538 kit for carb number 64-7128
I haven't been able to find anything on the Motorcraft number or the 7128 list number specifically.
If you can find someone that has the 3-538 kit in stock, match up as many gaskets as you can before opening the packaging.
Sweet yeah I just called pep boys in orange (good, smart guy there) he matched it up and has a kit that will work in stock. Thanks all
