Tech Talk => Engine Mechanical / Electrical => Topic started by: kenai on January 04, 2013, 12:06:03 PM
Hi All - just installed a pressure regulator (boost) on my 350/berkeley pump boat. all that equipment checks out fine. the cooling system is closed - jet pump to exchanger to barr log exhaust. the regulator knocks back the pressure and volume of water going thru the exchanger and out the logs. after installation i noticed carbon in my antifreeze...with a closed system I am scratching my head trying to figure out how carbon could even get into the antifreeze. anyone run across this before...thxs kenai
