Tech Talk => Engine Mechanical / Electrical => Topic started by: BIG JOHNSON on May 01, 2012, 10:12:44 AM
Resealed my risers on Sunday. I noticed a lot of calcium/scale buildup in the manifolds, like a lot. Anybody ever run CLR through a cooling system?
Also I got a handful of sand and small rocks out of the riser on passenger side that was packed in there.. explains why my exhaust tip on that side has some tan bit of hue to it.
Sent from my ADR6400L using Tapatalk 2
CLR is not supposed to be used on aluminum.
Anyone got any idea of what to run through the jacket to get good percentage of the buildup out? Muratic acid and water?
OE 800
Muriatic acid doesn't like aluminum either.
Don't really care about cosmetic effects, its only going through the jacket, not gonna polish the valve covers with it.
What's oe 800?
OE 800
I think I figured it out.
i cant wait till the day when my boat is so clean and perfect that im worried what the inside of my water jackets look like. LOL. sounds like you need another boat to keep you busy!
Haha, probably not. Mine needs a valve job at the end of season... Maybe that will make me happy.
Then again, probably not. I want an engina compartment that will put 82Daytona's to shame.
"Muriatic acid is a dilute solution of concentrated hydrochloric acid. This is considered a "strong" acid. It will rapidly dissolve aluminum( forming aluminum chloride) but not harm any of your rubber hoses or other plastic parts."
I wouldn't do it. But hey what do I know.
I'll buy that. But I don't think CLR will eat its way out of my manifolds.
SSSHIT I still got a few tricks up my sleve
One of them steering wheels made from chain links welded together in a circle and chromed?
See if you can find some mechanical contractor buddies to score you a couple of leftover gallons of Rydlyme.. http://www.rydlyme.com/home.html (http://www.rydlyme.com/home.html)
Basically a buffered electrolyte.
I have some at the shop, but it would cost a small fortune to get it to you (stupid heavy)...
Get a small pump and just circulate it around for about an hour, they will come out like brand new with little to no corrosion.... :thumbup: :thumbup: 8)
I use about 200 gallons a year cleaning condensers and towers. Works pretty good for a biodegradable solvent....Rather use Muriatic acid, but you can't have it all.
That's the method I was thinking. I have an extra RV house freshwater pump. Hook it to water inlet from the jet and pump till it trickles from exhaust then let it sit a few hours, flush then refill. Followed by a quick trip to a local lake.. after flushing as thoroughly as I can.
Rydlyme is what I use here at work on one of our machines. The stuff works killer :thumbup: :thumbup:
Should I look for the marine version, or standard Rydlyme?
When I store my boat, I drain the water out of the block and put fresh water and clear vinegar into block.
Only know of the standard type, don't know of any other. Check their website tho
Big J, Honestly I have only used the industrial.
But I would imagine the marine stuff would work for you.
Didn't know they sold a marine version Glenn
According to Condenser Services it has only been out about a year.... :thumbup:
Cool I learned a little something :thumbup: That shit works awesome in the machine I am using it in, have used it for quite some time.
Was told by AZ Americas, the German manufactuer of the machine, and Goodyear about the use of it, just a fyi
