Tech Talk => Engine Mechanical / Electrical => Topic started by: waveblast on April 01, 2012, 08:09:15 PM
Title: engine problem first jet boat
Post by: waveblast on April 01, 2012, 08:09:15 PM
i recently bought a 1996 kachina with a 454 bored .30. Guy said had 6 hrs on a new motor. I was going about 30 MPH and the engine made a few clunk sounds and died. Looked in pump didn't see anything. Took plugs out and since it died on lake it cliks once loud and motor will not turn or try to turn over. Do u think motor is locked up? I did get on it hard about 8 times for about 5 min each time. Has a dominator pump and read u can't disconnect without pulin engine. Any thoughts on what my problem might be
Title: Re: engine problem first jet boat
Post by: TJS Nordic on April 01, 2012, 08:12:50 PM
Do you have headers or logs. If headers, what do you have for a water control.
Post by: waveblast on April 01, 2012, 08:51:28 PM
Post by: mobboss on April 01, 2012, 10:33:50 PM
look at the oil , with the plugs out see if it will turn over manually easy thou. good luck!
Post by: GregS on April 02, 2012, 08:40:49 PM
Well  I'll add my 2-cents...even IF you haven't hurt the motor.  Unless you have an engine set up for enduro racing...."Running it hard for 5-minutes ( & assuming that lot's of wide open  )....IS like running on a dyno for 5-minutes. All boat engines are under constant load. You may be cruising @ 2500......but that's not like 2500 in your car. OIl temps go crazy with a stock oiling system...never mind the actual fuel mixture reaching outboard cylinders. Main & rod bearings get overheated in mere seconds.....So, if it ends up being something minor...very cool.   But suggest you don't run it that hard again w/o proper upgrade.
Good Luck!
