Tech Talk => Engine Mechanical / Electrical => Topic started by: hotblooded454 on July 16, 2013, 12:38:24 PM
Title: Engine won't turn off
Post by: hotblooded454 on July 16, 2013, 12:38:24 PM
We have a 1990 mantra gullwing jet boat with a 454 bbc. When we turn off the ignition the engine continues to run and the electronics (gauges) don't turn off. We tried replacing the ignition, and the wiring seems to be good. It is not the alternator because we disconnected it and it still happens. Any ideas?
Title: Re: Engine won't turn off
Post by: Beaveretriever on July 16, 2013, 01:00:31 PM
Does it have an hei? If it does are those leeds hooked up correctly
Sent from my SAMSUNG-SGH-I747 using SoCalJetBoats mobile app
Post by: Trukinbear on July 16, 2013, 01:09:52 PM
You're wired incorrectly somewhere - your switch does nothing but start the engine, right? Somehow your power is bypassing your switch, look under the dash and follow your wires from the switch perhaps you can find where the power is coming from. If that doesn't work pull fuses one at a time until the engine dies, then follow that circuit.
Post by: Trukinbear on July 16, 2013, 01:11:18 PM
my guess is in the 3 bundles of wires hooked to the switch, on the cold side you have a hot wire. Pull the wires off the RUN side of the switch, separate them then check for current with a multi-meter, or circuit tester. If one is HOT it's on the wrong side of the switch.
Post by: AQUAHOLIC on July 16, 2013, 01:15:14 PM
Post by: hotblooded454 on July 16, 2013, 01:15:31 PM
Thanks! It does have an hei. Will do what you guys suggested. Will let you guys know if it works/doesn't work. Thanks again!
Title: Alternator back feedinig
Post by: povertyjet on July 16, 2013, 01:21:14 PM
NOT AN IGNITION PROBLEM!!
The alternator excitor wire is feeding back juice to the coil wire through the “ign.” terminal on the switch.  You need to install a diode on the excitor wire.  The Radio Shack part number 276-1661 this is a 6A 50V rectifier diode ($2.49/pk of 4). Wire it up with the stripe toward the alternator.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.67-72chevytrucks.com%2Fvboard%2Fattachment.php%3Fattachmentid%3D318391%26amp%3Bstc%3D1%26amp%3Bd%3D1196463678&hash=68e376e1703f44b682e93f600cf47e3d5980df1f)
Post by: Trukinbear on July 16, 2013, 01:21:25 PM
Looking at the photo of your switch, I believe you have it hooked up wrong... are the 2 red wires on the right side HOT? (POSITIVE)
Post by: Trukinbear on July 16, 2013, 01:27:11 PM
Post by: Trukinbear on July 16, 2013, 01:30:36 PM
 I disagree about the diode - he says all his gauges and everything still work. If it was the diode the engine would run but everything else would turn off.
Post by: hotblooded454 on July 16, 2013, 01:37:54 PM
And I unhooked the wires from the alternator and the problem persisted. As for the ignition I will double check and test the wires. Here is a better pic of it.
Post by: hotblooded454 on July 16, 2013, 01:40:38 PM
The red on the ignition is a purple wire just the sleeve on the connector is red
Post by: hotblooded454 on July 16, 2013, 01:43:03 PM
As for the two red wires. They are booth hot.
Post by: Trukinbear on July 16, 2013, 01:49:32 PM
much better view, thanks... on the ING lug, is there only one wire there or do I see a 2nd one hideing behind the tape?
Post by: hotblooded454 on July 16, 2013, 01:54:50 PM
Yes there are 3 purple wires total 2 into the one connector and another separate one with its own connector hiding behind the tape.
Post by: Trukinbear on July 16, 2013, 02:02:06 PM
Have you checked to make sure one isn't hot? That is the most likely place for your wireing to get crossed.
Post by: hotblooded454 on July 16, 2013, 02:06:51 PM
Ok. We are going to start going through the wiring now. Thank you for your help. We will try everything you suggested. And I will post on here if we figure it out or not. Thanks again!
Post by: Beaveretriever on July 16, 2013, 02:08:08 PM
Check the hot leed on the hei. If you have it to 12v power all the time, it never loses power and the motor will j
Keep running until it runs out of gas.
Post by: hotblooded454 on July 16, 2013, 02:31:29 PM
One of the purple ignition wires is hot. The one that comes from the harness.
Post by: Trukinbear on July 16, 2013, 02:34:18 PM
BINGO!
Post by: hotblooded454 on July 16, 2013, 02:37:49 PM
What should we do with it?
Post by: hotblooded454 on July 16, 2013, 03:04:21 PM
Problem fixed! Battery cable was contacting the starter. Thank you for your help!
