Tech Talk => Engine Mechanical / Electrical => Topic started by: havasudre on February 20, 2007, 10:19:20 AM
ok this might be a stupid question but i found a pretty good deal on a rebuilt ford 460 does anyone know if all ford 460 have a 4 bolt main ?
Not one 460 BBF came with 4bt mains, they don't need it.
If you have any questions you can call me;
928-542-7712
Dre,
For future 460 information, check out http://460ford.com/ ...theres a ton of info there.
Hope this helps.
-Goad
cool im picking the motor up tomorow night and will have it in the boat by saturday hopfully we can get some more warm weather soon so i can get my boat out on the water
thanks Emanon Performance Marine for the great info
Since it's a fresh rebuild you had better make sure it was rebuilt for a marine application and not for a car or truck, otherwise it won't last you very long at all. ;)
The biggest concern is your piston to cylinder wall clearance. We usually run .003 more in a marine application. I have seen quite a few guys run automotive clearances and get away with it, but I don't recomend it.
We ran into this problem when we first got a 454. Water in the oil led to throwing a main. We rebuilt it, and had the same problem with water blow-by, minus seizing the motor this time. We retooled with a 396 b/o 402 with much tighter clearances. I really think this a tried and proven theory and a big mistake made by a lot of people using automotive specs in marine applications.
ok i picked up the motor . it was super clean . i met the guy who built the motor at the machine shop . the motor was supposed to go into a hot rod but he ended up not needed it he said he went throught the whole engine you can tell everything inside the motor was new i think i got a good deal for 500 bucks. the last motor i had got water in we are not sure how my friend said it came in thorought the exhaust flap when iwas backing the boat up to fast . the guy said who i bought the motor from said it should be fine in my boat because he built the motor for a hot rod
i guess only time will tell. worst case it last me a season and ill have all winter to rebuild it . i dont plan on running the engine to hard
ill have it in the boat by this saturday hopefully ill p ost a video of it once i get it running
here is the post
http://losangeles.craigslist.org/sfv/pts/280674860.htm
michaelr5343
how did you get water in your oil ?
I understand its a common problem with BBC/BBF motors not built to marine specs. We got water in the oil from too much pressure going into the headers. the water shout up into the heads. We got a Basset reducer and made a manifold to control flow to engine and two headers.
A friend of mine had a lot of engine work done on his Elininator by a marine jet drive pro. The mech installed a water control valve next to the driver's seat. Whenever his engine is below 2000 RPM he shuts the valve off.
I've also seen, with success, a water pressure regulator on the engine's water inlet from the jet drive. I've heard jet pumps put out about 200 - 300 psi, cars only have ...? what 14 lbs @ 200 degree's.
My Roger's, if I ever get started on it, is going to have thr-transom exhaust for the kid's sake. I'm going to use a water pressure reg. on the engine. Home Depot.
that might be the problem . only problem is i have no clue what a water regulator looks like and wich one i should bye for my boat anyone near riverside have one installed on there boat i would really like to see it .Im trying to make the boat somewhat reliable and anything i can to make sure it does not break down ill do but i am on a budjet . or ifyou have some pictures that would great
everthing is going to be pretty much new the starter altanotor water pump everthing so i want to do everthing i can
Here's one.
the image did not show up can you email it [email protected]
One more try.
is there a certian size i should get
thanks for all the info the motor going in tomorow and if it doesnt rain ill have i back on the lake withend a few days to break it in+
I can't find my jet's water outlet right now so you're going to need to measure yours to figure out the size. ???
I just want to clarify that 429/460 blocks were available with a 4-bolt main, but certainly not a 460 specifically (only in the 429)...nor were the 4-bolt mains used in the marine engines.
Indeed, the 2-bolt blocks are very strong and 4-bolt caps are not needed in almost every case. Finally, 2-bolt blocks may be converted to 4-bolt caps if absolutely necessary, such as in a blown nitro deal.
ok the motor is finally in the boat ready to go
we tried to start the motor last night but i think my carb needs to be rebuilt because its just dumping fuel and fluding out the motor so im going to get a new one today along with with a new distributor and see if i can get it to fire
the timing seems to be set right
is there any thing else i should look at
Quote from: Emanon Performance Marine
Quote from: Lakes Only
Don't those two above statements say exactly the same thing about 460's?
they are both right they did not have 4 bolt mains in either the only dif between a 429 and 460 is on the crank
i could be wrong but i beleive that the pistons were different specifically the pin location.
I have two D0VE blocks. The one currently in the boat has a two bolt main. The SCJ block sitting on my stand has a stock 4 bolt main.
Dre,
Hope this helps.
-Goad
Hi Brad,
I know this is an old post but thanks for the link. My Miller has a BBF 460 and this might be a good place to find out some general information.
Thanks,
Greg
