Tech Talk => Engine Mechanical / Electrical => Topic started by: Ralph Brunt on March 15, 2009, 06:49:19 AM
Title: fuc*ing drive shaft
Post by: Ralph Brunt on March 15, 2009, 06:49:19 AM
i need to change the oil in the boat and change my drive line, at about 3200-3600 it would growl then go away. i am not sure if  it's the shaft or the angle i set the motor :banghead: i put a shaft in that didn't need a pto because i wanted all the interior room i could get.
 we got the motor out
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2FIMG_0028.JPG&hash=c1ea0868bbd8ba4a1986b824069321c771c0969d)
then set about to remove the shaft
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2FIMG_0030.JPG&hash=fd7386d2d67ec6ed398759436d967adda7d56185)
then this :banghead: :mad: note to self dont use locktite on bolts. pops always told me not to use it here
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2FIMG_0035.JPG&hash=ed0ffca30d11e59f9b35959a3f3fda679e0bd8d1)
i stared to chisel it out but that was getting me now where O0 :banghead: these are grade 8 bolts so drilling them is next to impossible. i dont have a torch to melt the lock tite so i stick the drill in there and build up  some heat, and walla
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2FIMG_0034.JPG&hash=af0a91c21d117e72d3fb2ef62cb5be65ca11eb10)
the end result ;D >:D
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2FIMG_0038.JPG&hash=2083bd67fc384c2fdd7545cbef8b37269987f62d)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2Fnormal_IMG_0037.JPG&hash=43c96e4386b9d1645ea5f193c5461f570f60f0bf)
you can see the new shaft with pto in this pic
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.socaljetboats.com%2Fcpg%2Falbums%2Fuserpics%2F10041%2FIMG_0040.JPG&hash=ef0eb2f62707c5a32f73480ab6eb0782f86f6da1)
oh yeah, got the oil changed too :D
Title: Re: fuc*ing drive shaft
Post by: GT Jets on March 15, 2009, 11:34:44 AM
If it's not one thing it's a friggen 100, how straight is the DL? I cheat, I set the motor dead on then raise the front of the motor a tad (tad= 1/4"-1/2") I have a couple of drive shafts I made that don't have U-joints, they're a piece of pipe welded to the splined and pto yokes, but dead on straight. Glad you got it out, that had suck written all over it...
Post by: BOOST on March 15, 2009, 12:57:45 PM
Check out pops hard at work,does he even let you help ;)
Post by: Sanger Pete on March 15, 2009, 04:40:58 PM
Every team needs one talker and one doer.
BTW I'm the talker.
