Tech Talk => Engine Mechanical / Electrical => Topic started by: coors909 on May 13, 2016, 09:24:31 PM
I have a BBC 454 I was wondering what electric fuel pump I should go with. I was thinking the Holley red or blue?
Sent from somewhere in Cali
Well, I personally don't like either. Lol
If funds permit, look at Aeromotive.
But if a choice had to be made, Holley Blue and a pressure regulator.
What should the pressure be set at? Which aeromotive and does it require a regulator?
Really depends on the set up as far as which pump.
Holley carburetors should be getting a constant 6.5psi.
I have this guy going into the Jet boat.
900 cfm on a 496.
http://www.aeromotiveinc.com/product/ss-carbureted-pump-regulator-kit-an/
And a relay with that blue holley!!!
Stay away from the Holley pumps, they are junk. Aeromotive makes a nice internally regulated pump that runs a constant 7psi. That would probably work great for that 454
What's wrong with the Holley fuel pumps? I have been running a Holley blue for 5 years with no problems
The old ones were great. For the last several years they have been made in China and are garbage.
JMO
I will look it to that today. I had a Holley blue in my last boat and it only lasted 3 months.
http://www.aeromotiveinc.com/product/h0-fuel-pump-38-npt/
I was looking at this one and the red one that needs a regulator
the Aeromotive SS pumps are very nice, but if i can make a recommendation. Get a pre-filter.
The impeller in the Aeromotive SS pump is plastic, and i have personally broken two of them
The red one in the bottom of the pic is an aeromotive one
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv643%2Fsteves86ta%2FMobile%2520Uploads%2FIMG_20160120_074810_zpsmsq7mcza.jpg&hash=da5ba9d800ff015a90a4ac119990405745b7e3b2) (http://smg.photobucket.com/user/steves86ta/media/Mobile%20Uploads/IMG_20160120_074810_zpsmsq7mcza.jpg.html)
Heres the pre-filter im running. It seems to work great now that i figured that out
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv643%2Fsteves86ta%2FMobile%2520Uploads%2F20160127_124120_zpscakdqmfk.jpg&hash=08ae876ed117123125031bfa8d5d45f4733f579d) (http://smg.photobucket.com/user/steves86ta/media/Mobile%20Uploads/20160127_124120_zpscakdqmfk.jpg.html)
Where would the filter go?
before the pump. after your tanks tee together
Is the tanks still top feed ?
I only have one take on this boat. It's up under the bow
Holley HP150 with pre and post filters, Regulated to 7psi, feeding 2x4 4150's Zero problems....
What micron pre filter would you guys recommend.
150 micron with a magnet of you can find one. I think Raycor makes one that is also a water separator.
Thanks GT just for learning info would it be any different with running a mechanical fuel pump
IMHO, a lot different. The particulate tolerances are much greater in a mechanical pump simply because of how they work.
A mechanical diaphragm pump can almost pump mud. The limiting factor is the check, or gulp valves inside it separating the chambers. Once they get fouled, they get weaker and weaker until they hang partially open.
An electric typically has very tight mechanical tolerances and the smallest bit of hard material can lock then up solid.
Where did you buy your filter at?
This looks interesting.
Not too terribly priced either.
https://www.pegasusautoracing.com/productdetails.asp?RecId=9560&utm_source=google&utm_medium=cpc&utm_campaign=SET-IF0606D&gclid=CjwKEAjwpfC5BRCT1sKW2qzwqE0SJABkKFKR05sQ_GI0u9dnRkt4bgBHr10c5vMteDcqz3hp7gzzrxoCRCbw_wcB
Thank you. I can work that price it's under a 100
900 cfm on a 496.
Does this come with an external fuel filter?
I bought this fuel filter. Now just need the fuel pump next. I sometimes wish I was spending this money on a whole different boat.
when you're on the water it will all be worth it 👍🏻
Yes it will be!
Does anyone of pictures of where they mounted there fuel pump and regulators at?
Please I know someone has to have some pictures.
I will take one of mine Friday If you don't have any by then
Mine is on the transom. Easiest for me. I'll look for a picture
Here's a pic
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv643%2Fsteves86ta%2FMobile%2520Uploads%2FIMG_20151017_145649_zpstn5mebb7.jpg&hash=2c157047a2e6f2a1d6c16503c88f64b3979c28f2) (http://smg.photobucket.com/user/steves86ta/media/Mobile%20Uploads/IMG_20151017_145649_zpstn5mebb7.jpg.html)
Thank you
Hope that helps. Just used the stick bracket my regulator came with
The amount of horsepower that your engine has will determine how much fuel flow is required to support that engine. As horsepower increases so does the volume of fuel required to support that power. A good estimator of volume to power is approximately 10 hp per gallon or 2.64 hp per liter. For example if your pump flows at 50 gph it should be able to support a 500 hp engine (50 x 10 = 500). However, to actually know the gph you must also consider the fuel pressure required for your engine
That, and you cant go off of the ratings on these pumps. They are not accurate once you add in your hoses, fittings, etc.
I was going to buy the aeromotive fuel pump the red one with a regulator
thats a good pump. Just make sure your tanks are clean. Or run a pre-filter
Can you adjust the regulator to what pressure you want
I bought a pre filter a few weeks ago.
My Olds : I'll be using stock(upgraded Mondello pump)mechanical fuel pump w/ a Summit regulater and Holley d/P line kit.
That 1st pic is Bunger's inn-gine......soo sweet. (Hope he's not pissed for using it)I think.
Second is mine that I'll use one of these days.Life's getting in the way tho.
That white gauge in the first pic is water temp?
My engine does not have. A mechanical fuel pump
I believe that's Bunger's engine. That's an oil pressure auxiliary oil pressure gauge.
My hat is off to you guys who could afford the prices of these pumps and filters. You must have 7 figure incomes.
The white face gauge was a water pressure gauge I was using to get my relief valve dialed. Bottom gauge is a mechanical oil pressure and top is fuel pressure. The water pressure was just temporary
No 7 figures here. Not even half lol
I saved 3 checks to buy mine and even then summit gave me credit for the a aeromotive I was returning
No 7 figure income here. I just keep saving for one part at a time.
We are all a bunch of broke asses
We own boats definitely broke
Mount the pump where it won't get wet. I used to run a blue holley. First one failed (leaked) after a season and a half. Second one also failed but half way through season. This time I decided to take it apart. There is a tiny hole on the body. Water got in through there and rusted the shaft just behind that hole. The rust on the shafts ate up the seal. It's probably what caused the first one to leak too. Ruined my day both times. I will never run one in a boat ever again. Now I have mechanical. No switch, wiring, or relay to fail. Good luck.
I had the same problem. I'm not a fan of the Holleys
Just bought this beast!
thats a great pump
That's the same pump I bought been a great purchase...
Awesome Glenn told me about it. I have had my eye on it for a couple months just have been saving for it.
Same regulator I use for my nitrous side. Love it
Awesome! The boat haul I have don't think it would last of I had nitrous lol. I wish I would be putting all this cash into a full stringer with a Berk pump. I'm to deep now the wife will kill me
I would say I'm using the same one for my carb. But I bought the black/red one that's the same except the fittings are o ring fittings. The silver/red one are npt
I hope it works great. I have had good things
my only complaint was the red turned pink kinda quick
That's ok
Can you adjust the fuel pressure on the fuel pump?
No it's factory set at 14 I think. That's why you have the regulator
Is regulator adjustable?
Have a picture of your regulator? If it's same as mine it'll have a 3/16" Allen bolt with a jam nut. You turn in or out to adjust pressure then tighten the jam nut again
Yep, loosen the jam nut, and the Allen stud is the adjuster.
It might be realitively close out of the box. I use my gauge off that port right on the side
Ok thank you. I read the instructions lol after I talked to you. Seems like those help sometimes.
