Tech Talk => Engine Mechanical / Electrical => Topic started by: AQUAHOLIC on July 21, 2008, 07:23:25 AM
ok i have a set of hardin marine water jacket type headers. the heades are a casted water jacket type. i know i got from my pump to the water jacket to fill them with water so that it can be preheated before entering the block. the water then extis the water jacket and enters the engine. Should it enter at the top of the motor at the thermostat or enter in the water pump ports on the front of the motor.
after the water leaves the engine it is routed to the exhaust to exit the boat. Now on the stock hardin marine exhaust there is an intermediate pipe that connects the header to the transom. This pipe also has a water jacket on it. My question is can i just replace that with regular stanless tubing? if the water is just getting dumped out the back of the boat anyway why would i need a water jacket back there.
I was just going to create new intermediate pipes and weld a bung in there for the exit water. but was not sure if this was ok or not. i cant imagine what it could hurt by doing it this way. i just wanted to see what you guys thought.
The standard way is for the water to enter the block at the water pump inlets and dump through the thermostat outlets.
I read somewhere that a few people have set it up as "reverse cooling" where you do it the other way around but I honestly cant see any real benefit to it. Some say it makes the heads run cooler that way.
Here's a diagram I found.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fgregaw.home.comcast.net%2Flogplumbing.jpg&hash=f02fa75a14bc6d88069cb4152ea2c91930b3a85d)
thanks guys.
ok here is where i am a little confused. if you follow the red line back to where it dumps at the snails. On my new exhaust set up i am going to run 4 inch stainless and i was going to weld a bung in there for the water to enter the exhaust pipes and leave the boat. is this going to work just fine?
thanks guys.
4 inch? ??? Why the heck so big?
that is the size of the hardin shit that i am putting on. and the size of the tips. haha. looks pretty mean on the back of the boat.
i called hardins tech support and the guy was real helpfull i dont know why i did not do that in the begining.
anyway he pretty much cleard it up for me. that intermediate waterjacket pipe is to cool down that section of the exhaust so that you dont melt your rubber flex line that attaches the exhaust to the transom tips. i will post some pics tonight of what we have done so far.
