Tech Talk => Engine Mechanical / Electrical => Topic started by: AMG on March 22, 2012, 09:29:43 AM
TOTAL BONEHEAD MISTAKE!! and feel like a total dummy! Went out to the river this weekend to do some wrenching on the boat, drop it in the water and do a test run. Then tow it home to replace the floor. Well in my rush to get everything hooked up and in the water before the rain started again I swapped the wires on my No.1 battery. I flipped the switch and immediately saw my wires glowing red, tried to flip the switch back off but it erupted in white smoke and was going for a good 15 seconds before i could reach back in and shut it off.
_______________________________________ __
Visible damage:
Positive wire from #1 battery to switch melted
Positive wire from #2 battery to switch melted
Negative wire from #1 battery to ground melted
Negative wire from #2 battery to ground melted
The common wire from the switch to the starter stayed intact.
The stereo wires both positive and negative which were connected to #2 battery both stayed intact.
I replaced the switch with a new perko
New positive wires for #1&2
New negative wires for #1&2
New common wire, switch to starter.
2 new batteries
Hooked up everything yesterday for a test fire, stereo worked, But I got no response from the motor.
What else do i have to replace? My thought is the starter, but this board has the knowledge, I don't. Any advice is helpful, I'm trying my best not to take it to a shop and spend unnecessary money.
Thanks in advance,
Aaron
hate when i do something like that when in a hurry :banghead:
what about the ignition switch wire or key switch? time to get out the test meter and buzz it out or see where the power stops flowing. sorry thats all i have. good luck :thumbup:
Key switch, Ill look into it
starter should be fine.
if its a HEI distributor theres a chip inside under the rotor... thats probably toast once you slapped some positive juice up the negative... you can crank it over and pull a plug and see if you're getting spark.
it wont crank at all or i would try that
starter or starter solenoid. use a jumper wire from the battery to test em.
this may be a dumb question but how would i go about that? just a direct connection from battery to the solenoid to see if it clicks over?
thx,
Aaron
never mind, youtube handled that question. Ill give that a try tomorrow.
