Tech Talk => Engine Mechanical / Electrical => Topic started by: bac Tahiti on June 04, 2011, 09:25:01 PM
Title: Help 460 fuel pump
Post by: bac Tahiti on June 04, 2011, 09:25:01 PM
I need some Help with my fuel pump.  Looks like I'm getting black rubber or something coming from it.  Not good.
Do I need a marine fuel pump or will a electric or regular manual one work.  Need your help...    ;D
If electric what kind and what about marine.
Thanks as always.... ^-^
Title: Re: Help 460 fuel pump
Post by: Brad @ SCJB on June 04, 2011, 09:57:45 PM
stay with a mechanical.   :thumbup:
Post by: GT Jets on June 04, 2011, 10:04:55 PM
I always recommend going marine where possible, not always easy. Theoretically it is not 100% necessary on an open engine set up, but closed it is an absolute must.....
Electrics work pretty well but there are some things to consider. You have extra wiring and an extra load on the electrical system, so your alternator size (amperage) needs to be considered. It is one more parasitic draw on the electrical system and will become an issue only if you have a charging system problem.
There are some plumbing concerns also. Many times a high performance electric fuel pump needs to be regulated, so the cost of the extra parts needs to be taken into consideration.
For your 460, I would recommend getting in touch with Clay Smith Cams (Mr. Horsepower) and finding out some information on their fuel pumps (mechanical), I have heard nothing but good things from them here on the boards....
Good luck and don't overlook the potentially flawed fuel supply lines and a good filter system is a must.
Post by: Brad @ SCJB on June 04, 2011, 10:08:44 PM
this is what i run on the race boat...its never given me a peep of a problem. just make sure your water blockoff plate bolts arent too long  O0
Post by: IRRebel on June 05, 2011, 01:06:28 AM
X2!  :thumbup: Clay Smith Mechanical here.........never a hiccup, burp or fart.........
Post by: bac Tahiti on June 05, 2011, 08:26:54 AM
Thanks, I'll stick with the Mechanical and new lines.  I already have filter but it is before the pump and I believe the rubber is coming from the pump?
As always you guys are great.
Post by: bac Tahiti on June 05, 2011, 08:46:02 AM
Just was on Clay Smith's but didn't see Marine???
Help. :-[
Post by: Your Mom on June 05, 2011, 08:47:29 AM
If your pump is falling apart...replace your pump. I have a carter marine (5-6 1/2lbs bout 42gph)on mine vented to the arrester.
Post by: Your Mom on June 05, 2011, 08:50:35 AM
Help. :-[
I have a new marine carter on my shelf in box that I might consider selling for $75 plus ship.
http://www.summitracing.com/parts/CRT-M60562/ (http://www.summitracing.com/parts/CRT-M60562/)
Post by: Brad @ SCJB on June 05, 2011, 09:39:52 AM
Help. :-[
i wouldnt worry about the marine aspect with a mechanical fuel pump.
the one 'your mom' has will work for you.  :thumbup:
Post by: 79charger on June 05, 2011, 07:22:15 PM
I have a Holley red mechanical and it works great ......Too good .....
  I have to regulate it down actually ...... ;)
Post by: bac Tahiti on June 07, 2011, 08:31:13 PM
Purchased a Carter pump with a vent (marine).  Can I run the vent line back to the fuel filter or does it have to go to the tank?
Thanks for the advise.
 ;D
Post by: Your Mom on June 07, 2011, 09:48:37 PM
I run the vent line along the fuel up to the arrestor...Its a tight bend right by the head so zip tie it to the fuel line to keep it away from the heat.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fimg409.imageshack.us%2Fimg409%2F7845%2Fyourmom5.jpg&hash=af39fa48cc740b40bab5907bf41c4a84333800d3) (http://imageshack.us/photo/my-images/409/yourmom5.jpg/)
Post by: GT Jets on June 07, 2011, 10:15:08 PM
 ;D
Just so you know exactly what the "vent" is for.....The Carter marine fuel pump has two diaphragms, the second is there to literally keep the fuel contained in case the first fails and the vent is there to literally pump the fuel that would normally get sprayed all over the place (in this case the bilge) into the carburetor to kill the engine, or at least make it run like crap so you will be forced to take a look see.....
Great choice IMHO, be advised also that the pump is "clockable" meaning you can change where the in and outs end up.
Post by: CHROMEY on July 01, 2011, 09:50:57 AM
lots of good info in here...thanks boys!
