Tech Talk => Engine Mechanical / Electrical => Topic started by: lance.sportivo on February 06, 2014, 11:13:54 PM
Just curious if anyone knows of a good place around the Temecula area that does log polishing for a good price.
A friend of mine used a place in Elsinore next to American Materials, I think it's called So Cal Polishing. He thought they did a good job on his logs, not sure on price.
You could polish them yourself and it would only cost ya 30-80 bucks depending if you have a bench grinder or a 8" variable angle grinder
Yeah I started sanding on them myself a bit but I don't really have the time to finish them. They were pretty rough.
I've had good luck using wd40/wet sand (not water) to get them ready for buff.
What's the advantage to wd40 wet sanding over wet sanding ? Isn't a pain to clean off when it's time to polish ?
I saw an episode years back about using wd instead of water on aluminum with paper. Don't remember the details but it definitely adds to prep before polishing. This is a pick of a set I bought from Jim Brock years ago. They were in rough shape and tried the wd/sandpaper trick. A good buffer/material will bite most light to medium damage. The sanding with wd allowed the worst damage to be minor or unnoticeable.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi897.photobucket.com%2Falbums%2Fac178%2F2ndlight%2Fmylogs_zpsfdafb260.jpg&hash=00d434c1ec72ae09865923e2d6e4dded0d384e6e)
