Tech Talk => Engine Mechanical / Electrical => Topic started by: Rkb on June 07, 2018, 06:43:23 PM
Title: LT1 IN A KONA
Post by: Rkb on June 07, 2018, 06:43:23 PM
Just got all the parts in for my 1995 LT1 then I'm going to put in my 1980 Kona jet boat I know about the reverse cooling system for the LT1 and how it all plums together in the car what is the best way to plum it from the jet drive cooling system
Title: Re: LT1 IN A KONA
Post by: mash on it on June 07, 2018, 10:09:51 PM
Even though it s an Lt1, I'd still cool it like a traditional big or small chevy.
Is it that much different from an sbc?
My faux ZZ4 is plumbed the same way.
Post by: Grimpala on June 08, 2018, 04:46:32 AM
Plumb it to the water neck first instead of to the block.  Pretty simple swap.  The cooling system was designed to run in reverse so I'd leave it that way.
However, unless you're swapping to an old school dizzy or putting cool on plug I would think twice about running an LT1 in a boat.
The opti was pretty much junk on a street car where it saw minimal moisture, a jet is going to be hell on it.
The cool thing is, you can machine the intake and modify it to accept a dizzy off of a 99-00 Chevy van and then run updated OBII with a newer ECU and you get a decent top mount dizzy with FI control.
Sent from my HTC One_M8 using Tapatalk
Post by: Grimpala on June 08, 2018, 04:47:18 AM
If you do run it, run a vented Opti, not that early crap.
Post by: mash on it on June 09, 2018, 04:15:59 PM
So, how do you keep the heads cool, without forming steam pockets?
Post by: Grimpala on June 11, 2018, 02:12:33 PM
Plumbed to the neck first it'll feed the heads then the block.  Correct?   Then out the block where the pump would go and off to the manifolds.
Post by: Grimpala on June 11, 2018, 02:17:00 PM
After thinking about it for a second, an LT1 would be a little difficult to plumb in a boat without some sort of adaptor.  Since the water neck is part of the pump you'd have to have a plate made up that would feed into the block on the top, then out on the bottom.  Basically two fittings on each WP attachment point instead of one.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.grumpysperformance.com%2Faug2017%2Flt1asd.jpg&hash=610a915dc88416b5c77fc3762db70d7d9516a83d)
http://garage.grumpysperformance.com/index.php?threads/lt1-vs-lt4-corvette-engine-parts-differences-useful-links.13141/
Post by: steves86ta on June 12, 2018, 07:15:57 AM
You could plumb it like i did my ls
Make the front motor plate the inlets and outlets for water
If you aren't doing a rail kit and plates then just make a plate with pipe fittings. Same theory
Sent from my iPhone using SoCal Jet Boats mobile app (http://r.tapatalk.com/byo?rid=201)
Post by: mash on it on June 12, 2018, 10:13:45 AM
X2
Filling the block first, and exit out the top. Minimal chance of steam pockets in the heads.
Exhaust choice would determine the plumbing route of the water hoses from the pump. (Headers, logs and snails, Merc center risers, etc)
Post by: Grimpala on June 12, 2018, 11:00:48 AM
An LT1 is designed to cool the heads first.  I would think that plumbing to the block first would be bad for cooling.  The heads are designed to work this way and don't look like normal SBC heads with regards to cooling passages, steam pockets wouldn't be an issue like they are on a standard 350.  They're more like a 400 for cooling than they are a 350.
Post by: mash on it on June 12, 2018, 11:33:36 AM
And lt1 also has a closed cooling system in a car.
A jet boat engine, just sitting in the water is mostly dry / empty.
When water enters the top, it will seek the path of least resistance, and out the back, leaving the majority of the block and heads uncooled/dry.
If you restrict the water on the exit, you will over pressure the block and heads, pushing out a head gasket or even the core plugs.
When an Lt1 is in a boat, car rules no longer apply.
With a whole lake full of water, reverse flow cooling or not, it WILL stay cool. Exit temp should be 120° or so with headers.
Post by: Grimpala on June 13, 2018, 11:32:40 AM
When you say "out the back", what do you mean?
The lake full of water makes sense, it's going to cool either way, just thinking it should be plumbed the way it was designed.
My understanding of how a jet cools the motor is that the block fills from where the water pump would normally mount, fills the block, then the heads, then out the water neck to the exhaust.
Why wouldn't you plumb the LT1 the opposite of this, so that it fills the heads via the upper water pump holes, and then the block, then exits via the lower water pump holes?
Post by: mash on it on June 13, 2018, 03:29:07 PM
If you plumbed it from the top, the block and heads would not 'fill' the entire cooling area. It would simply exit out the water pump ports.
Also, some of the theory on a reverse flow cooling system is to cool the heads with the coolest water from the radiator, to the hottest part of the engine, rather than cooling the block first then the heads, sbc style.
What's normal for an Lt1? 195° ? 210° ?
A good, I mean really good radiator drops the temp by 50°. Most are less.
So 195° coolant drops to 145° at best. The engine WILL add 50°, and the cycle continues.
So lake water, at 70°, on a single pass thru the engine, should gain 50°, and run at 120° or so with headers, and 140° or so with logs and snails.
Just my $0.02
Physics and thermo-conductivity played a part, too.
Post by: bahner80 on June 13, 2018, 09:19:42 PM
Good thread.
But dan l is rite on  in an open loop system you want to supply the water from the bottom and out the top so it pushes all the air out. Avoiding the steam pockets y’all are talking about I do commercial and industrial refrigeration and 100% of our evaporators, chillers are piped that way heat transfer is the name of the game.
Just my.  02
Post by: Grimpala on June 14, 2018, 11:12:45 AM
You guys plumb it however you want, it's not my boat.  But if I was doing it, I'd run it the way GM designed it.
http://www.enginebuildermag.com/1999/09/rebuilding-the-chevrolet-lt1-engine-2/
Quote
EXTERNAL COOLANT LINES
There is an extra hole that goes into the water jacket on both ends of the heads. These should be plugged when they’re in the front, but left open when they’re on the back. There’ s an external coolant transfer line that connects the holes on the back side to a reservoir that vents the air and steam vapors that would be trapped in the head and cause hot spots.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.enginebuildermag.com%2Fwp-content%2Fuploads%2FArticles%2F09_01_1999%2F99928agif_00000003985.gif&hash=c6ea446bdb805c51e330d3a9a9cc1adb7ff11af8)
Post by: 1BGBDWF on April 29, 2019, 12:41:31 PM
The last post on this was in 2018. What did you end up doing and how did it work out?
