Tech Talk => Engine Mechanical / Electrical => Topic started by: 1sttankbn on July 01, 2013, 06:24:17 AM
I have a 460 Ford running a 2 wire Motorola 37 A model # MR12N451D that is only running on about 10 volts on the gauge. I pulled it off and took it to have it test at 2 places and neither (pep boys or O'Reilly) place could do it. Is there a easy switch from this 2 wire system to a 1 wire or should I purchase a new one or have this one rebuilt. Any help would be greatly appreciated!
did u use a volt meter and test the alternator on the boat. if u have a weak cell in the battery it will read low on the guage. if it is the alternator rebuild it yourself. the parts are available at napa or carquest.
No I pulled the alternator and battery off the boat. Battery tested perfect so I'm rebuilding th Motorola
Sent from my ZTE N9120 using SoCalJetBoats mobile app
That souls be awesome PM and let me know where to come get it!
