Tech Talk => Engine Mechanical / Electrical => Topic started by: el mojado on July 31, 2014, 04:32:34 PM
What are some opinions between the 2. I'm building a 20.5 70s cruiser. 454 .30 over w mild pop ups which are supposed to be 10.5:1 comp, 049 heads, marine cam, 750 vac sec, Ebrock Air gap, logs, jacuzzi WJ. I have an MSD dizzy and box thats in good shape. But I'm leaning towards installing an HEI only because if I have an issue I can go go Vatozone and pick up a module, cap, or rotor. In this application would I be hurting performance? Would I even notice? Which is more reliable? Having a hard time deciding. Thanks.
Sent from my SCH-I535 using SoCalJetBoats mobile app
i think its a preference thing to a point. I hate the look of a big bulky HEI, looks retarded to me haha. If you have the MSD i would just use it. Autozone or o'rileys have msd parts 3/4 of the time.
I'm an HEI guy. You definitely won't hurt your performance one bit running an HEI, they'd fire a nitro motor. I agree with the ability to diagnose and fix them easily with parts from a junk yard if need be.
I will agree with Jake on their looks. They're like a fat chick that puts out. Not going to win any beauty contests, but you now she's a sure thing. :sly:
Are you worried about money? If you have one why the question is it old?
Second question why would you need parts for it?
Are you going to use mechanical advance? I hate vacuum operated anything.
For hella money u can do MSD stand alone no extra box to mount.
There is no doubt that the HEI is a good bang for the buck, but for being an inductive ign. system it does have it's limitations. I've had a GM system on my boat before, and had misfires at WOT, then tried a Pertronix system that shit on me twice, then finally went with the MSD marine 6A and the marine pro-billet dist. and have never looked back. I have been using MSD Ign. in my big block Chevelle for 21 years without a problem and the 7AL series in my 7 sec. alcohol dragster and never had any issues either.
The box I have is not marine. How much of an issue could that be? Can I just try to install it in a dry spot?....I'm still on the fence with this.
Honestly, I have the MSD Pro Billet Distributor using a 6AL box and a Mallory box coil, IMHO, bulletproof. This setup has been in four different boats, two of which were Marathon racers.
That being said, I also use the factory Thunderbolt systems for closed engine applications. It is basically a hall effect sensor, a CD Box, (which is like a Ford Dura Spark module) and a coil.
I have only used a GM type HEI, and if they were not so prone to water damage, I would say it is a good way to go... But they sure are clunky...
JMHO
I run Unilite in both my fords without any drama...
MSD Standalone
Yeah its 500 bux but no box Marine Its Billet and great bang for the buck.
All about what u wanna spend.
in a boat it should be simple stupid.add a box and all that other shit is just asking for a problem on the water. At the most inopportune time. Which is usually when your in the middle!!!! Go with the HEI ! Its basic and not alot of moving parts!
Any more horror stories with eithr one? I think I'm beginning to lean towards HEI
If you already have the msd stuff why don't you run it????? Save some money else were
I'm leaning towards ease of installation and availability of parts should something go wong. If I have an issue, each part that can fail in an HEI is less than $30 bucks and readily available. If MSD failed that would be an expensive boating weekend. And there goes beer money. Still going back n forth in my head with this. MSD stuff I have is good to go. Just needs cap and rotor. Anyone have MSD 6A fail on the water? And why?
Decided to go HEI. ease of installation, simplicity, less parts, and parts availabilty. Gonna save the MSD for land hot rods. Thanks for input!
Hei all the way there super easy to install and reliable
Just throwing this out there. It is not a matter of IF and electronic device will fail, it is a matter of WHEN it will fail. Both the HEI and the MSD are electronic devices and are susceptible to failing and as ka0tyk pointed out, it is always “at the worst possible moment.”
If you would like to run the MSD, you can always make an emergency backup pigtail and HEI module (mounted to an aluminum plate as a heat sink). It is small enough to keep in a water tight plastic box such as where I would keep an extra set of spark plugs etc.
You could always go for the cool factor and wire in two MSD boxes NASCAR style. Carrying a backup MSD box is an option too. If you do go the HEI route, I would also carry a backup HEI module.
Another option, that will bring on the controversy, is a Vertex magneto. Simple, reliable, and self contained. It only uses one ground wire to “turn it off” and no power is required as it generates its own. The most common failure is internally shorting out the coil from too much resistance i.e. resister core plug wires, resister plugs, and too wide of a gap (.019 recommended). The electricity has to go somewhere and if it can’t go through the plug, it will make its own path internally. Another common failure, in a car, is de-energizing the magnets by welding on the chassis while the mag is installed or polishing the mag body.
Cheers,
Joe
Cheers,
Joe
So are u saying I can wire in an HEI module to my MSD distributor!?
Yes, either the 4 or 7 pin HEI module will work. The 7-pin HEI module won't use 3 of the pins that are used for the computer controlled timing advance and will rely entirely on the mechanical/vacuum (if applicable) advance in the distributor.
What I was getting at was, you can make an emergency pigtail utilizing an HEI module to get you home if the MSD fails. Or you could hardwire it on a switch NASCAR style.
Sent from my SCH-I535 using SoCal Jet Boats mobile app
