Tech Talk => Engine Mechanical / Electrical => Topic started by: TJS Nordic on March 08, 2008, 04:57:17 PM
I decided to machine the injector pockets on my plate for my 8-71 BBC EFI Jet Boat project. I machined the blank plate a while ago with the help of a friend who has a Haas machine.
All in all it came out great. I took my time, did some simple math and measured 3 times. I bought a 14mm injector pocket cutting tool from Ross machine. I am using 96 Lb Rochester style injectors. This took about 30 minutes or so to do. Next up fuel rail machining from Ross Machine fuel rail stock
Here is a critical part if you want your project to be straight. Indicating the fixed jaw of the vice. I am only .0003 (that is 3 tenths of a thou.) out from one edge to the other.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate10.jpg&hash=f7b71a4ce2b6b82e3e594e25df436446cda0f465)
After Locating the edge of the part with an edgefinder I was able to use the digital readout. Here is the cutting tool ready.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate11.jpg&hash=db257e12b4683e34fbffb58b3665fa6962efb56f)
After doing some simple math I found the points to where to machine the holes for the injectors. Here is the first hole spacing. Notice the Y-Axis is 0000. This is the center of the plate. This should not move during the whole process.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate12.jpg&hash=b32ded821da94b561453081a23717b6bb5bccdc4)
Notice the tink marks from the cutting tool in the alum. What I did was space out using the digital read out and then make sure I had my math correct.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate13.jpg&hash=a3b639680820671bf7d18e5fb73071bbed437aba)
Here is the first hole cut.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate14.jpg&hash=caf57321ebb78a8806a5df6968f610a48e8a61dd)
Checking fit up and the depth. This is critical. I had to machine, clean and check the depth a few times to where I wanted the injector to sit. I then set the Z-stop and all the other holes were all the same depth.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate15.jpg&hash=d09876b10770fc4be7a52b3731f05c1772ceb8fb)
A few minutes later and all the holes are done for one side.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate16.jpg&hash=82d5e15f1755b5cfef096bd48d6c881a450ef8db)
Flipped over the other side. Notice the angle plate acting as a "stop". This lets me keep the tool in the machine with out taking it out and finding the X and Y edges again.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate17.jpg&hash=aeaaaeb0998e79e406ae1a752b41789e8d9298b0)
Here is the plate mocked up with the injectors set in place.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate18.jpg&hash=2f962689d404a8bdbe9ddabbf6deae081849deae)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate19.jpg&hash=25d59bbf496b46713245b8ecd2faa5355412a441)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate20.jpg&hash=7d1be4f293c7aa80b9443eea7ea5dd0f041f7353)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate21.jpg&hash=3406c3c3577a2181e7a4eeda37c8034ff02c6266)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate22.jpg&hash=76bb1407be92973acb55ccf900522969b1b6026d)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate23.jpg&hash=4ab24f848c628a95edd78e736f171fe40496226e)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate24.jpg&hash=0bc7040fe25d6d33c5672f8569a7b3b2de331cef)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Finjectorplate25.jpg&hash=258f99a213577b10d850ad4f6e843c1bd0c185d6)
damn good work! looks awesome!
very nice work :)
very nice work :)
Very nice indeed
Good job. What efi system are ya using.
Not sure yet. I have not gotten the "box" yet. I am thinking the Accel Thruster set up.
Very nice and clean ;D
Dam, I just got a stiffie..... ;D
EE Errr My 02?? stay away from the accel!!
One of my buddies tried the accel on a procharged alky sbc with terrible results!!! Not good tech support,and non linear changes. I can find out what system he changed to. It was very simple!!
He actually kept the motor in one pc. It's a 69 camero he's gone a best of 7.02 @ 197 at 5600ft.
Another buddy with the turbo mustangs likes the FAST system. A little more involved but stable.
My 02.
Good work!!! I'll help in any way possible. 8)
I've heard nothing but good things about the FAST system . I'm not an EFI guy either sooooo.....
Ok today I machined the fuel rails matching the numbers on the digital readout from yesterday's injector plate machining. Rails are -10AN from Ross Machine. I have to devise a way to hold the rails to injector plate. Some sort of bracket. I might use Ross machine mounts for this.
Here we go. Cutting the fuel rails for the length I think they are going to be. I have never done this before and I am learning as I am going.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_01.jpg&hash=2d2c06d57998f75f42b8de1d180de158a3850740)
Even though my saw blade is damn near square to the saw vice I always square my materail in the Bridgeport. It just makes it easier in the long run. This also allowed me to get the rails exactly the same length. I also calculated for some "hang-over"
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_02.jpg&hash=4e8827442fc7199ef4a0d9f329702a916d91a32d)
Another critical point to mention. The rails are round so they want to move around in the vice. You can see some square key stock I cut to hold them close to square. I finished up indicating the rails to the spindle both X and Y.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_03.jpg&hash=caefb9519fd6df689ad9f29400a22a2a9df8f521)
The Ross Machine tool is well worth the money. I set the depth and machined away.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_04.jpg&hash=588eaa6583f163dad1b39f0be1779fe10632b01d)
Here they are all done except for the threaded ends. I need to mock up first to see if I need any trimming. Sweet huh.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_06.jpg&hash=171ede5b3e4183f217b0814adda4d6cb60f08f1e)
Mocking up. Damn this is cool.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_07.jpg&hash=810dd1994f1afecd51bd45f530cfcaaa6dbf70af)
Sorry for the poor pic. I don't know what happened.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_08.jpg&hash=996d9ce67f095772ba3d3f75fd60c69661b0d8ea)
Yup, interference as I thought. The throttle position sensor hits. I marked it and will trim it. Good thing I left some hang-over. Once I get the length to where I want I will machine them for -10AN O-ring with the O-ring boss tool from MSC$$.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fefi_fuel_rail_10.jpg&hash=78ba6e4ad06ba4eb2b41aabff3be297186cbbf96)
TJS, I followed your boat build on your website, nice work. Now you go and top it off with this? Sheesh! You're making us look bad, no serioiusly, this is great, thank you for taking the time to share it with us. You want to adopt me? ;D
Very cool thread, very nice work, sweeeeet.
Thanks everybody. I do not consider myself a machinist by any means. I work in the corporate world and sit behind a desk all day. Fabricating and welding is my passion, especailly with aluminum. I do not want to show off either. I just want people to see with a little creativity and not a lot of money, many things can be made for what others sell for a lot of $$. This is my first time building an EFI set up and I am learning as I go. Just posting to maybe help others if they have an idea like this.
Thanks again.
Can a bracket from the spacer to the fuel rail work for ya? It doesn't have to be a ridged mount.
Perhaps a hole where the AN fittings go through on frt and rear? I love this stuff!!! ;D I just finished helping a guy put a snowmobile motor in a gyro-copter. Lots -o- head scatching! But fun!!!
I'm a machinist ...if ya need imput I'm only a keyboard away. ;)
Thanks. I was looking at the Ross Machine brackets. The ones the sell are designed for the tall bosch injectors (LS1). I probably still can use them and machine them down. I was also thinking of using alum flat stock and make a big "U". Kind of wrap the "U" around the round part of the fuel rail. Then tig weld some flat stock perpendicular to the "U" with two holes in it and thread the plate. I am just thinking out loud.
Thanks.
You might look into the Wolf system for fuel management. A friend used it on a turbo Nissan in a sand rail with good results.
http://wolfems.cart.net.au/cat/3754.html
Made a new Page on my site covering this project.
http://www.tjsperformance.com/blowerEFI.htm
Hey Tjs, do you know if anyone makes an adapter to go from a blower manifold to a dual carb set up?
does it even work?
Have you run it ? how do it do ???
tj i must comend you, that is some beautiful f'n work :o
does it even work?
No it is still work in progress. On the back burner right now. I want to enjoy the boat in N/A form right now this summer. I will finish this project in cold winters we have here.
This one has 16 injectors and stainless lines instead of rails. Works awsome
We've taken a slightly differen approach on the same theme. We're using the high capacity Holley injectors and feeding internal to the spacer body. This way there are no exposed injector rails. The fuel is supplied to the smaller holes in the bridge between the two sides.
Cheers, Mark
Mark,
That is a cool idea. Are the holes in the ends of the spacer plugged after you drilled the passage for the fuel. Are the Holley TBI injectors low impedence, what LB/HR are they. I am running 96 lb/HR low Impedence Rochester style injectors.
Exactly right. There is a crossover passage then two lengthwise passages, one per side. The longways get plugged just to the inside of the bolt holes that fasten the hat to the blower.
The injectors are 85lb/hr Holleys. Low impedance (PITA) but 2 for $25 new on ebay.
Controller is a MegaSquirt which is built and tested from the basic kit (CPU and PCB). We will have around $600 invested in the complete EFI system (including the Enderle Bugcatcher) when done.
Cheers, Mark
Very nice work. Im not running a blower but I have a fast EFI with threaded 72 pound seimins low empedence. I just finished it. It works great and tho the fast is $$$ it works great and has a ton of capabilitys, spelling lol.
Nice. I had a tunnel ram set up for EFI and I sold it to do this project. My buddy tells me I should have kept it and made plate to adapt a Throttle body and go turbo. I know turbos are more efficient but I like the looks of an 8-71.
PS-Rompstomper. Do you have and vids of that. Power output etc. EDIT: Nevermind I found your post.
