Tech Talk => Engine Mechanical / Electrical => Topic started by: Wayne Zighter on January 13, 2012, 09:15:11 PM
just curious on the pros and cons, whats everybodys thoughts and preferences on pressed rods versus bushed rods
It is my humble opinion that unless you plan on turning it stupid tight (above 6K+/-) I would stay with press fit pins.
It really depends on the build and use. With the torque a jet requires the full floating rods are a luxury that is both unnecessary and potentially a negative. The negative part is because of the higher cylinder and oil temperatures.
