Tech Talk => Engine Mechanical / Electrical => Topic started by: Nordie on February 21, 2011, 09:58:34 AM
So if you seen my other thread on the puke tank you already know that i am planning on using my evac tubes for water...this is to keep water police off of my case at some destinations on the river...this piece is only temporary on a broke ass bidget so here it is
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2F184.72.239.143%2Fmu%2Fd0362744-a740-2edc.jpg&hash=5d197ad3a6f64376c7190f438e5c5eba93175c1f)
As you can see i like using my intake mani. to keep it from driving me crazy
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2F184.72.239.143%2Fmu%2Fd0362734-a795-8d52.jpg&hash=77e59b21f15b9231bd68ab3f36611dc811671fad)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2F184.72.239.143%2Fmu%2Fd0362734-a7c2-65f4.jpg&hash=990323640d0f1d409e112e4075e9b90249820ff9)
I don't understand what you are trying to do.
To have wet exhaust but for it to dump at the tip besides at the bottoms of the primary tubes...i cant have wet exhaust due to cam overlap...plus i dont have any provisions for water...so i used the evac tubes to run water and not half to worry about water in the pipes
The OT's I have have a fitting near the same area as your evac fittings. My water flow is from the pump to the water jacketed glenwoods manifolds, into the thermostate housing, out of the waterpump ports and to the OT's. I used a gate valve to regulate the water flow to get the desired operating temperature.
unfortunately you are comparing apples to oranges...the tubes on the headers that i have water running through are actually set-up to be like the breathers on your valve covers...the exhaust creates a vacuum effect and pulls the crank case pressure out of the block...now i am using the puke tank that the blue lines coming off of the valve cover are going to...it catches excess oil, and is used as the breather...the now available tubes that are on the headers i am using for water...he changed from a tube going from the valve cover to the header, to a tube to a catch can, then is going to fun a water line to the tip of the header... so it LOOKS like he's running water from far.
is there ANY chance that water will go backwards out of the header and down to the exhaust valves?
there is that possibility, but i am hoping the distance that has to go i am hoping the water turns to vapor by then...i am thinking there is going to be very little water if any to make it to the head...but a plug reading will tell that tale...i have a video of it working in a little bit...
the camera mic hates the exhaust, can you say distorted? nothing too spectacular
video-2011-02-21-14-04-27.3gp (http://www.youtube.com/watch?v=dUXaCj53gI8#)
video-2011-02-21-15-05-21.3gp (http://www.youtube.com/watch?v=aIg0ACdDLnA#)
you da man josh O0
I had that setup on my old v-drive. Make sure that the water coming out of the fitting will squirt past the collector with whatever pressure you have at idle, or you'll end up a motor full of water. I had mine positioned about 3 inches from the tip, and the fitting had a 1/4npt hole aiming out the back....I had a little nozzle made out of pipe to get the water out....until one broke off and the motor filled up with water when I got off throttle. It you need some fittings, let me know....I can whip up a set with nozzles for ya
hey patt the evac tubes are about 1" away from the end of the collector if i am understanding you correctly
also the fitting is chocked down to 1/4"npt
Ok...looks good then
im still trying to picture what you had in mind...i dont want my engine full of water :thumbdown:...i figured my troubled area would be getting off of plane, but so far it only seems to mist, but a water test will tell more with the pump pushing the water
Picture a stream of water exiting the collector without touching the inside of it....just like a nozzle pointed backwards
understood! 8)
What is the law regarding water to the headers? Does anyone know the intent of the requirement? What areas of the river are the rangers looking for the wet stacks?
i believe it is a general rule, and i would say most places arent really going to care much, but i would also say that heavily populated areas of the river will probably enforce it more then other places...or use it as a reason to check for a dui...technically it is considered a muffling device...this deal i built is to run on parker for the weekend and then it will come right back off! i havent had a single problem on mead, and even on a holiday weekend two rangers drove by my idling boat and just waved at me...mind you the exhaust was facing the covered slip parking, and was really echoing loud...i have gotten the finger a couple of times from the regulars that sit on the dock and watch...the other people love it! think one trip i might use terrys zoomies for shits n giggles!
looks like the boat is full of fuel in the video :thumbup: ;)
The beav
The beav
the only gauge that is no worky...wish it was full of fuel
