Tech Talk => Engine Mechanical / Electrical => Topic started by: Huffa on October 05, 2012, 02:15:06 AM
Title: Supercharged 350 Chevy-Cooling system
Post by: Huffa on October 05, 2012, 02:15:06 AM
I have just put a 350 Chevy in my jet boat running a Weiand 671 supercharger and am trying to work out a suitable cooling system. I want to continue to run a water pump as I did with the non supercharged motor but the trouble I am having is with the thermostat hole on the inlet manifold faces forwards rather than upwards like a traditional manifold and there is a lack of room. Has anyone got any suggestions on what thermostat housing would work for me? Thanks
Title: Re: Supercharged 350 Chevy-Cooling system
Post by: mash on it on October 05, 2012, 08:36:47 AM
Just thinking out loud here-
A merc 302 ferd type t-stat housing?
Post by: carlitos on October 05, 2012, 11:55:29 AM
Heres a swivel style water neck that mite work
 http://www.summitracing.com/parts/SUM-371101/ (http://www.summitracing.com/parts/SUM-371101/)
Post by: Huffa on October 05, 2012, 02:37:02 PM
Heres some pics. This is the old motor with thermostat housing attached[attachimg=1] This is a Rex tpe thermostat housing I have . Its a non water pump housing. They are not recommended for blown engines and I am not sure if it would even work mounted on its side. [attachimg=4] [attachimg=5]
Post by: carlitos on October 05, 2012, 03:29:59 PM
Is it necessary to run a water pump in ur set up?
Post by: Huffa on October 05, 2012, 03:39:12 PM
Well I have been advised by the performance jet boat engine builder to run a water pump. The non water pump systems seem very crude as cold water is going into the block and thermo shock can be an issue. But I am willing to look at anything. The trouble I have is here in New Zealand no one really runs 671 blowers in family boats so I dont have any other similar set ups to copy.
Post by: obnoxious001 on October 05, 2012, 05:57:22 PM
I don't know who all sells these,, but Teague has a bunch of different ones similar to this one.  http://teaguecustommarine.com/index.php/stainless-steel-thermostat-housing-18.html (http://teaguecustommarine.com/index.php/stainless-steel-thermostat-housing-18.html)
Post by: TJS Nordic on October 05, 2012, 08:11:58 PM
Never had a problem with my open system. I made this housing.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2FCHHtstat3.jpg&hash=47b4c03e329dc6e6fe1000b2de984de40d0331d8)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fzoar_6-30_2010_03.jpg&hash=e257ada9adc4e0a57cd3b0d7a89a3699f4933459)
Post by: IRRebel on October 05, 2012, 08:58:28 PM
Why not a remote Tstat housing? Then you could use that housing cover you have
www.moroso.com/catalog/images/63426_inst.pdf (http://www.moroso.com/catalog/images/63426_inst.pdf)
Post by: Huffa on October 05, 2012, 09:13:13 PM
Thanks for that guys. Yea it would be nice to bolt something directly on and keep it tidy. TJS Nordic how long have you run your system for and do you run your boat for long periods at a time? What temp does it run at and does the temp fluctuate much? My running is an hour or so one way normally in braided shingle rivers.
Post by: obnoxious001 on October 05, 2012, 11:47:05 PM
Are you using the boat for ski racing or something?
If you are running the engine hard for extended periods of time, it's common over here to run as much water through the engine as possible.  I personally ran blown and turbo engines in a Schiada ski race boat, with a large cam driven water pump.  The turbo engine had all -12 water lines.  Hottest I ever recall it getting was a weekend when I pulled an Aussie skier at Lake Mead in Men's Open class,, air temp was about 115 degrees, and at the end of the race after I dropped the skier off I saw 190 degrees on the gauge, that quickly came back down as I let the engine continue to idle to cool the turbos and normalize temperatures.
PS... I also build engines for a living, so there is more than one school of thought on cooling.  My 1000 HP turbo engine was in the boat 6 years, and still in good shape when I took it apart for inspection after selling the boat without the engine.
Post by: Huffa on October 06, 2012, 12:04:19 AM
Thanks obnoxious. The boat is purely for recreation but I do like to run reasonably hard. So did the 1000hp engine you had run a water pump system? If you were me what set up would you use? Water pump or non water pump?
Post by: IRRebel on October 06, 2012, 12:27:48 AM
Barry's talking about a V-Drive style pump driven off the camshaft, which I think would be another great way to go! No longer need the regular water pump or belt, much smaller and could probably run that apparatus off the front of that Weiand intake with room to spare!  ;)
This is a fuel pump on this timing cover, a water pump is much smaller (Can't find a pic of one at the moment), but you'd need a new timing cover, the water pump and the drive spud obviously.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi673.photobucket.com%2Falbums%2Fvv95%2FIrrebel%2FParts%2520for%2520sale%2FP8220014.jpg&hash=82eb93f1d1f85162632ff7852cd2658911666912)
Post by: Huffa on October 06, 2012, 01:03:59 AM
Thanks Ray. That could be an idea.
Post by: TJS Nordic on October 06, 2012, 11:27:00 AM
170 all day long. Short trips long trips and hammering it.
Post by: Huffa on October 06, 2012, 11:48:37 AM
Is your water pre heated in any way before it goes into the block?
Post by: TJS Nordic on October 06, 2012, 01:10:13 PM
No.
