Tech Talk => Engine Mechanical / Electrical => Topic started by: muffbro on June 08, 2013, 07:40:23 AM
The exhaust hoses from snail to thru-hull on my float are old and a real pain to remove and re-install..... Yesterday one started leaking..tried to stop it by swapping ends .... Spinning it etc .. But the rubber is so hard (and even with the wider T style clamp) I cannot get it to stop..... That would NOT be cool for it to come apart out on the lake.
I guess I should have replaced them when I had everything apart but......
Sigh...
How about some opinions ( I KNOW there's a couple out there ) on what is a good hose to use. I have looked online and there are a lot of different kinds, wire type... non wire....including pure silicone. The silicone are pricy, do they last? I see them used in automobile Turbo set ups... They are heat resistant, but how about in the long haul??? Do they stand up? To Oil gas etc???
Standing by:
there is a specific hose to use , any really good auto parts store will know which hose is correct. It does not have to have the wire in it. the stuff i just got from my auto parts store seems to hold up great! It was really expensive ! it was almost a 100.00 bucks for 4ft length of it. its the black hose with the green strip on it.
I double clamp on both sides just in case...
The back hose with the green stripes is from Gates., pretty cool stuff. Not cheap but cheaper than silicone. Works great
More and more of us up here are going with some stainless tubing with a couple of silicone couplers on each end. Another option for you
That too is an option.
in the same boat (so to speak)... anyone use silicone ? (tween) risers & tips
A friend used silicone and melted right through it.
good enough... thx
Its really not a place you wanna have questionable materials.
[/quote
hear that, looks cool doesn't mean is cool?]
I always thought, and have read, where Silicone is good for upwards of 500 degrees plus....the water/exhaust coming out of my logs is that not that HOT... I can hold my hand in front of the exhaust when its running and it IS hot....but I also know its significantly cooler than a dry header system.......
Sure I'd like 'simple and easy' to attach to the thru hull ..... Those thick azz hoses i have now are difficult to install.....that being said, That's a big ole hole below the waterline that I want sealed correctly.
Ok,...after some research: Silicone has a higher temp rating than the EDPM standard such as Trident / Gates or Shields standard wet exhaust tubing.... Corrugated/wire/ no wire/ soft-wall.
Average for EDPM 250 to 275 degrees. Silicone: up to 350 degrees.
Silicone is MUCH more expensive....
A different way as previously mentioned on this thread: From snail to silicone coupler to SS tube to silicone coupler to thru hull is workable, but I personally don't like the idea of multiple connections/clamps.... So I am going with either a Shields or Gates soft wall EDMP and double T style clamps on both sides.
Now I just gotta find a place to buy a 3' stick if the stuff ...... Me living 300 miles from the ocean or any real boating centers means more 'net time .....
Thanks for the input guys.....
FYI: I bought my 4" silicone hose from McMaster-Carr years ago. I think you can buy it any length you want. Sorry, no part #.
Found a great deal on some Shields exhaust hose on eBay. Installed and now leak free. It was a breeze to put on compared to the old rock solid stuff that was on the boat when I bought it.
Sent from da phone
OK...here's the final product.
It was much easier to install the new hose than to remove the old hose...( petrified... rock hard....leaking )
It was a great price too... less than $40.00 bucks including shipping ( I ordered 3 feet and got just shy of 4')
I also tossed the old worm drive clamps for stainless "T" style clamps I bought at Fastenal.
UPSIDE DOWN PHOTOS ???......... :screwy:
