Tech Talk => Engine Mechanical / Electrical => Topic started by: Nixonnow on August 23, 2011, 09:53:47 PM
Title: to gasket or not to gasket. logs, BBC.
Post by: Nixonnow on August 23, 2011, 09:53:47 PM
ok so i have read that running a gasket will somehow cause the logs to warp and in turn have an exhaust leak. what do you guys have to say about the subject? they are hardin logs on a BBC. just run a gasket? run a gasket with rtv on both sides? or just use rtv and no gasket? and if so...what kind of rtv?
Title: Re: to gasket or not to gasket. logs, BBC.
Post by: IRRebel on August 23, 2011, 10:06:42 PM
Use a gasket. Any tiny imperfections in either surface will be compensated for. Just use the proper torque sequence go in 25% at a time, and use the hell out of Gaskacinch (Both sides of the gasket, the head, AND the manifold).........You'll NEVER have a leak doing that unless something is VERY wrong.
Post by: Your Mom on August 23, 2011, 10:26:52 PM
A good set of Harman logs and felpro gaskets....The water in these type go up towards the ports.
Post by: Willow Wog on August 23, 2011, 10:31:34 PM
O my sbo I never used a gasket on my logs just a shit ton of black rtv. Never one leak
Post by: crewchief22 on August 24, 2011, 06:36:26 AM
I used FelPro #1410 header gaskets on my logs with very good results.  I always installed them dry but adding sealant isn't going to hurt anything.
My engine had studs with brass nuts for the exhaust manifolds when I bought it and I continued to use them until I changed it over to headers.
Post by: Nixonnow on August 24, 2011, 08:08:11 AM
Thanks guys. I'll look for those fel pro 1410's. My engine doesn't have studs. Just ARP bolts. What kind of sealer would work best? The gaskacinch or rtv? And what rtv?
Post by: NORDIC454 on August 24, 2011, 08:23:38 AM
Alex, when I had those logs on the Nordic, I have used both ways. The headers I used to build for the race trucks, we never used gaskets. Just Right-Stuff rtv to seal it. so I did that with those logs. When I rebuilt the motor I got a set of the metal header gaskets with my gasket kit and used them. They worked great as well. They didn't leak at all. I think you'll be fine
Post by: MPKardell on August 24, 2011, 09:23:09 AM
I've never used exhaust manifold gaskets in 25 years of running logs on motors (iron and aluminum heads).
I use the "copper plus" rtv.
I always use studs, instead of bolts.
My 2 cts....
Post by: Nixonnow on August 24, 2011, 03:45:31 PM
Picked up a set of fel pro 1410's and a bottle of the "right stuff". Gonna slap on the new logs soon. What's the difference between bolts and studs being in there? Bolts are what's holding my current set of logs on. Thanks again guys.
Post by: 79charger on August 24, 2011, 06:33:06 PM
Orange "copper"RTV ..... Let them set up for 10 minutes and I install them finger tight . Come back 30 minutes later and torque .... never a problem and I run Harman logs .
Post by: Nixonnow on August 24, 2011, 07:10:22 PM
so should i install the gaskets dry or with the "right stuff" on both sides of the gasket too? i just dont wanna get them on and realize.......oh crap i should've done that too.
Post by: obnoxious001 on August 25, 2011, 02:13:12 AM
I would suggest using a thin coat of high temp silicone (the red or copper one) on both sides of the gaskets.  The "right stuff" may be similar enough, but I am not familiar with it.
