Tech Talk => Engine Mechanical / Electrical => Topic started by: fastnlight on May 07, 2013, 07:11:50 PM
Title: Water pressure guage location
Post by: fastnlight on May 07, 2013, 07:11:50 PM
Have a BBC with a water pressure regulator.  I want to install a pressure gauge and was told to install it on the block somewhere.  Is this a good location?  It would be where the plug with the hex head is.  Are there better places?
Title: Re: Water pressure guage location
Post by: GT Jets on May 07, 2013, 07:43:31 PM
I see nothing wrong with that location, with one small exception..... It's ugly. Why not install it in one of the 1/4" pipe holes on the bottom of the block?, it would be invisible..  ;)
Post by: fastnlight on May 07, 2013, 09:11:46 PM
Yeah the thought of that guage sitting there didn't sit real well with me either.  I'll look for one of those pipe holes.  Are you talking about just putting it right in one of those holes without tubing.  If so, I'm assuming this isn't a guage you look at a whole lot.  Do you just use it to set the pressure relief valve and then not bother looking at it very often?  I really don't know, I'm new to jets.
Post by: GT Jets on May 07, 2013, 09:14:05 PM
I never, never, never ever put a gauge directly on the engine... They don't hold up well to the vibrations, especially a bourdon tube gauge.
Install a remote gauge and use nylon tubing much the same way you would install a mechanical oil pressure gauge.
Post by: TJS Nordic on May 08, 2013, 05:35:56 AM
Never had an issue with looks or vibrations. Also helps when you Mother In Law works for Ashcroft who makes gauges for Navy ships as well as subs for US military.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fblown_nordic13.JPG&hash=fa3858e2b025c2bdea736f9f69ef33789789f6f7)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fblown_nordic14.JPG&hash=eaf1e593ac8f8e579166cd4caeeb7de607a4759c)
Post by: GT Jets on May 08, 2013, 06:50:35 AM
Ashcroft makes nice stuff.
The little (I assume fuel pressure gauge) is fluid filled and is not mounted to the block.
Also, your stuff seems to be the exception to virtually every rule. 8)
You have to be really careful with Bourdon tube gauges, tough is one thing they are not.
Back in the racing days (extreme example I know) one of the guys put a mechanical oil pressure gauge on the back of the engine for testing,I hated it, well it blew apart and squirted all the oil out if the engine before anyone caught it, danged the crank and made a ginormous mess.
If you have ever taken a pressure gauge apart, you will immediately understand. Temperature gauges at a different story.
Glycerin filled is the only way.
Post by: fastnlight on May 08, 2013, 08:42:51 AM
It looks like your water pressure guage is hooked up to that braided line with the blue anodized fitting?  Am I seeing it right?  Beautifull motor by the way, and your hood hornament ain't too bad looking either.
Post by: TJS Nordic on May 08, 2013, 09:05:26 AM
It is actually in the t stat housing.
Post by: jet fever on May 11, 2013, 10:00:59 AM
So do you have a regulator with built in relief off the pump.
Are you looking for the pressure of water going into your block? does the water flow to the block then out the Thermostat??? Is there a Thermostat or are you controlling flow from a gate valve
I set mine [Regulator with built in Relief] with the garden hose to relieve then placed it in the boat.
Post by: fastnlight on May 14, 2013, 09:57:06 PM
Yes my regulator is right off the pump and the water does flow through the block and out the thermostat housing.  My regulator does have a relief that goes overboard through the transom.
I'm still trying to screw my head on straight after reading the exchange between you and GT Jet on the other water regulator thread.  I need to set aside an hour or two and reread it.
Anyway, I will keep in mind the garden hose option.  Thanks for sharing.  Didn't think of that one.
Post by: GT Jets on May 14, 2013, 10:18:03 PM
 I promise not to start that sh!t again...  :screwy:
If I may. Why do you want a gauge? Do you run headers? is your dump line visible from the drivers seat?
Have you thought about one of these?   http://www.basspro.com/Teleflex-Marine-Eclipse-Series-2-Water-Pressure-Gauge/product/10200206/ (http://www.basspro.com/Teleflex-Marine-Eclipse-Series-2-Water-Pressure-Gauge/product/10200206/)
Post by: fastnlight on May 14, 2013, 10:28:20 PM
No problem, for the most part I thought it was a healthy debate.  By the way, I just posted a reply on that thread.  Check it out.  I didn't want to jack my own thread.
Anyway, yes I do have water cooled headers and no the dump is not visible from the drivers seat.  I just thought a guage would provide useful information.  I don't have a clue what my water pressure is and I don't want to blow a head gasket.  I don't know, do I really need one.
Post by: fastnlight on May 14, 2013, 10:31:13 PM
Looks like my reply on the other post didn't go through.  The pic was too big.  I will take another tomorrow and post.  I was going to ask the question:  Why do I have a pressure regulator and then a gate valve after.  Seems redundant.
Post by: GT Jets on May 14, 2013, 10:33:48 PM
IMHO    no
Ever heard of a Pete's plug?
Pretty slick little device that works like a basketball fill port... You can attach a gauge to an adapter and spot check it...
Post by: fastnlight on May 14, 2013, 10:45:02 PM
IMHO    no
I just Googled it.  Interesting.  I could probably put one on the plug on the T-stat housing I originally considered.
Post by: GT Jets on May 14, 2013, 10:49:01 PM
Yeah, you could, they're not too bad looking either.
I use these on a daily basis... What size do you need? I will drop one in the mail. I think the adapters are pretty cheap. Then you could use just a regular old POS gauge.
Post by: fastnlight on May 14, 2013, 10:54:45 PM
Wow, I appreciate it.  I'll see what size it is tomorrow and let you know.  Thanks!
Post by: jet fever on May 15, 2013, 02:59:23 PM
Google Jim Coffey he has jet boat cooling info on his site.  He builds pumps and performance engines.  He use to work for Berkeley and he built race cars.  Maybe if u don't take my opinion u can soak in his info.
Sent from my LG-P509 using SoCalJetBoats mobile app
