Tech Talk => Engine Mechanical / Electrical => Topic started by: desertracerlv on April 18, 2014, 02:04:24 PM
Do I have to buy an expensive marine battery to use the boat or can I just get one from autozone for a 454
Sent from my SCH-R530C using SoCal JetBoats mobile app
I get mine from Costco like 75/80 bucks and 1 yr full replacement it's also a marine battery I have 2. Both work great for my bbc
SRC
Sent from my iPhone 5 using SoCalJetBoats mobile app
Diehard platinum (sears) are the same as an Odyssey. 👍
Awesome thank you
Im calling around for the battery How many cranking should it be
Where are you located?
I also use the Costco deep cycle marine batteries, i believe there around 700cca
SRC 🚤💨
I'm in vegas
Thank you I will call costco how abput a battery from autozone will it be the same if its not a marine battery
Im not sure about auto zone
Ive used the Costco batteries for over 10 years now, 1 year full replacement with no hassles and its a deep cycle battery for under a 100 bucks
SRC 🚤💨
Cool thank you I will chek with them I just got all the old gas drained out of it and getting it ready for its first time out
What I'm working on
Its going to be awesome to be on the river soon
Good looking float.
Were heading out to Blythe for the weekend
Roll out if you can
SRC 🚤💨
Thanks for the invite I'm getting the boat together as fast as I can I found a battery for it at costco looks like it will be ready soon maybe next weekend it will be ready to go to the river
anything over 700, 750 clod cranking amps should be fine I believe
Here ya go
SRC
Costco Car battery here and its starting its 4th year now. Its a interstate bought at Costco for 65 bucks
Costco deep cycle it's the only way to go
New battery installed today! yes yes yes
How long can I run the engine without water hose hooked up to it
Never do that, but have heard max of 1 minute or 2. Always start first, then turn on water. Usually a few seconds after running.
Sent from my C811 4G using SoCal Jet Boats mobile app
Ok thanks I wasn't sure I just bought the boat and got a general rundown of the starting procedure when the boat is out of the water
Make sure your running water through pump and motor. If you can disconnect your pump from motor.
How do you hook the hose to the pump?
I put the hose in the intake making sure not to put it to far, and have water flow on high.
When the boat is out of the water is the valve suposed to be closed or open when the water hose is hooked up and when I take the boat to the river do I leave the valve closed or open when its sitting in the water after I get it off the trailer
I have always called BS on the water running through the pump deal.
All I do is spray water into the pump intake and through the nozzle to rinse out any potential crap/debris, back off the packing bolts and spray some Teflon lube into the packing seal and light it up.
I have run them for as long as 25 minutes an the trailer. Never hurt a damn thing. I run an Ultimate wear ring and a stuffer. The only drawback is that it's a little hard on the splines to rattle back and forth, spraying water in the pump will do nothing for that. I sometimes leave the DL out, but more often than not, let her buck.
Ever seen someone post pictures of damage on a pump from running it dry? Bet not. :sly:
[quote author=GT Jets link=topic=20301.msg230198#msg230198 date=1398044076
[/quote]
lol i had the pump lock up on my old hornet, focking thing stalled the motor and i thought the motor had seized, just ask Jim Brock he got the pleasure of rebuilding it at midnight on a friday night because i was making sure the motor was good before i went to the river...
just my personal experience
ralph
oh yeah, optima red tops,
i was racing at parker spun the boat and sank it, was running the next day with the optima, then i put it in the wife's car for 6 years... lets see your battery's do that..
ralph
Just curious more than anything. Would spraying some water in it have helped at all? Hoping you're going to say no.
Any idea what failed first?
water, rotflmao
not sure, i was working on the boat with my head down and tail between my legs as jim was building it because he warned me what would happen....
Love that hull style
How long after starting the engine do I need to turn the valve on for the water hose when the boat is out of the water its my first jet boat and I want to make sure I start it the right way
if you have headers it does not matter, logs after you start it,and if you want to do it rite you will disconnect the pump..
just my 2cents
I got it fired up with the garden hose ok today but when I take it to the river do I need to have the water valve open or closed
Which?
Wha? Who?
Whatcha mean?
Just got a spare tire I needed for the boat trailer today and the new battery and all bad gas put of the boat I'm getting closer now the boat fires up no problem what a sound that motor is in my garage I can't wait to hear it on the water
I mean the valve under the engine for the water when the boat is in the water do I need it to be open or closed when I start the boat out of the water and I hook up a garden hose I open the valve and water comes out of the headers so when I'm at the river I would assume I should have the valve open for water flow is that right
There is a hose conection in the boat to hook the water hose up at the house and reconect it for when ita in the water that has to be open when the boat is in the water doesn't it I just want to get the proper procedure down so I can take care of this cool boat and engine
Gotcha.
Yes the valve would be partially open. If this is a gate valve the valve setting is quite important.
Since there is no water pressure when the motor is not running, you don't need to close the valve with the boat in the water.
If you do indeed have water injected headers with a Bassett type tee, here is a proven way to set up the water valve (this is for a gate valve).
Get the boat in the water and pull out of the way of people at the ramp, find a spot out of the way and start the boat with the valve about half open and run it at idle, there should be NO water coming out of the headers.
After a few minutes of running, start closing the valve slowly (about a half a turn at a time) until the water temp starts to rise (look for about 140-150*F at the most).
Once that has happened, take her out for a cruise and watch the headers for steam, they should begin to steam at 1500-1800 RPM. If they come in too early (below 1500) you need to pinch down just a smidge on the valve (careful, those headers will be hot as hell). If they come in too late (above about 1800) you need a bit more water.
Your done. If something does not work the way you think it should, write it down.
Write down;
How many turns the valve is open/closed.
At what RPM the headers come in.
What the engine temp. is at idle.
What the engine temp. is at WOT and also cruise.
The temperature on the gauge might be all over the place for the most part. That is OK.
Figure about 150* at idle and probably about 120* or so at WOT. It can move pretty quick, so watch it for a minute or two before making any adjustments.
I keep my hand in the dump line stream when I am setting them up, but I have done over 100 of them.
Good hunting.
Forgot to mention. There is a chance that the overboard dump line needs to be bigger or smaller, so don't be too frustrated it the numbers don't quite work pout right.
If the engine runs too warm with the headers working properly, you may need a slightly larger dump fitting outlet.
Too cold, and you may need to restrict it down some.
Both are pretty easy, as long as the headers are working right, don't be afraid to drive it as long as the engine runs cool. You may get some condensation in the oil, but that's an easy fix with an oil pan heater.
Thank you that is a lot of good info I can use to gauge the activity of the cooling of the motor I really apriciate it I'm new to all of this but the motor and the boat is so interesting to me thanks again the first trip will be all learning and figuring out how the system works the boat is really coming along and with this crucial info it is looking like a winning plan thanks gt
Any time, also PM sent.
Also, bring with you a tie wrap or two, you cn run a tie wrap through the handle of the valve to keep it from moving all by itself (with the help of parking lot elves ;))
