Tech Talk => Engine Mechanical / Electrical => Topic started by: HardCharger on September 18, 2008, 10:35:15 AM
Title: WTF??????? sand filled bigblock!!!!!!!!!!!!!
Post by: HardCharger on September 18, 2008, 10:35:15 AM
So after removing my motor from my boat and completely tearing it down (not a good end to the season) I find that the block is filled with sand.  And by filled I mean allot 16lbs. to be exact.  Anyone else encountered this and does anyone run a filter on the water supply from the jet???  I have a panther jet powered by a 460, any tips aside from the obvious "dont drive over sand"; this is definetly years of sand abuse especially since I only drove the boat 3 times before blowing it up due to overheating and running lean.
Title: Re: WTF??????? sand filled bigblock!!!!!!!!!!!!!
Post by: OC2Vegas on September 18, 2008, 10:48:47 AM
most likely sitting on the beach running the motor sucking up sand or in shallow water
Post by: pw_Tony on September 18, 2008, 10:52:15 AM
The first time I took apart my motor, I had found the same thing.... the motor didn't ever over heat or anything, but it had a large beach in the block and heads.
I don't run anything to filter sand still, but I'm alot more aware in starting it in shallow waters. Up here I don't think sand is an issue, but down in Martinez where everything is sand it happens over time
Post by: HardCharger on September 18, 2008, 11:23:32 AM
Yeah thanks, I have pretty much figured out how it happened. ::)
I am just wondering if anyone else has the same issue and what if anything is anyone doing to prevent it.  I am certain this is from the previous owner(s) not being careful about where they drove the boat and maybe not flushing it out properly.  This condition also ruined a set of Dove-C heads.
Post by: realHawaiianJet on September 18, 2008, 08:32:00 PM
If you have big wads of cash laying around, you could get a sea strainer. :screwy:
But I saw awhile back someone had a strainer from McMaster Carr that they installed, and they even posted the part #, I'm wanting to say it was TJS, but not one hundred percent on that. It uses a fine wire mesh to filter out all the sediment from the water, and probably even gets more than a sea strainer would. I'll try to find it for you.
Post by: realHawaiianJet on September 18, 2008, 09:20:52 PM
Found it, here's the link to the thread.
http://www.socaljetboats.com/index.php?topic=3892.0 (http://www.socaljetboats.com/index.php?topic=3892.0)
Or here's the bit of information that really matters and the picture.
"Here is the part number and I used the mesh screen for it. Sorry I stand corrected it is good for 150psi.
9875K217
Nylon T-Strainer Clear Bowl, 3/4" NPT Female
$16.22 Each"
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.tjsperformance.com%2Fimages%2Fwater_inlet_adapter04.jpg&hash=2e1f452554261ce5c3bf00f337a36fa0b5a99314)
