Tech Talk => Engine Mechanical / Electrical => Topic started by: JOE COASTIE on June 03, 2014, 02:49:08 PM
Title: WTH is this for?
Post by: JOE COASTIE on June 03, 2014, 02:49:08 PM
So i need this and my mechanical fuel pump? Never had a hull with 2 tanks...its coming from both and this T's off to a single i assume to the fuel pump?
Sent from my PantechP9070 using SoCal Jet Boats mobile app
Title: Re: WTH is this for?
Post by: 74hondo on June 03, 2014, 02:51:37 PM
I believe it's so you can electrically select between the two tanks. It's usually recommended to not run from tanks at the same time.
Post by: jyeager on June 03, 2014, 03:00:55 PM
Yes that's what it's for. I do recommend carrying a spare. They do go out, I've been left floating Down the river because I had no way to switch tanks.
Post by: JOE COASTIE on June 03, 2014, 03:24:25 PM
Oh dam no bueno ..cool thanks guys
Post by: TrollerDave on June 03, 2014, 05:14:30 PM
Does anybody know why? I have a tee at my electric pump from both tanks.
Post by: lbhsbz on June 03, 2014, 05:15:11 PM
make sure it's grounded properly...my dad bought a boat and his switching valve was grounded to the screw holding it down to the wood/fiberglass subfloor.  Needless to say, that pissed me off....had to float 4 miles home.
.........and change your fuel lines....those don't look too good.
Post by: lbhsbz on June 03, 2014, 05:16:25 PM
They never seem to draw down at the same rate for whatever reason...
Post by: beerjet on June 03, 2014, 05:17:38 PM
For stuff like this, I prefer a manuel valve.
Its not the end of the world if you have to get out of your seat to switch tanks.
Not to mention its plastic.
The fittings are small.....
Just not for me .
Post by: JOE COASTIE on June 03, 2014, 06:31:54 PM
Oh yea definitely changing hoses
Post by: JOE COASTIE on June 03, 2014, 06:35:12 PM
Also thinking of a manual valve ...not a big fan of electrical anything lol
Post by: JOE COASTIE on June 03, 2014, 06:38:34 PM
its for cars, not boats.  wheres the manual ball valve to turn off the tank in case you have a leak?  not a fan of the electric valves.
it says for marine use only on it tho
Post by: todd98se on June 03, 2014, 07:15:11 PM
I used this on my Liberty. I mounted it coming up through the splash well. Probably not as easy to mount with a jet but it works great.
http://www.discountmarinesupplies.com/Groco_FV450X_4_Way_Fuel_Selector_Valve.html
Sent from my iPad using SoCalJetBoats mobile app
Post by: el mojado on June 03, 2014, 08:50:13 PM
All the high dollar boats are electric everything. Ive seen them with a large box thingamajig that controls left and right fuel tank.What is it? And about $500 bucks!
Sent from my SCH-I535 using SoCalJetBoats mobile app
Post by: el mojado on June 03, 2014, 09:05:15 PM
Interesting.  Thanks for the insight.
Post by: Brad @ SCJB on June 03, 2014, 09:40:36 PM
http://m.ebay.com/itm/Universal-Fuel-Tank-Switch-Over-Valve-For-Dual-Tanks-12-Volt-EZ-To-Wire-/320869592267
I use one in my ultra...works great.
Post by: mash on it on June 03, 2014, 10:54:03 PM
electric fuel valve-
I can change tanks, and re-fire,  before I come off plane...
Nearly 20 years old
1976 GM truck fuel valve
NOT USCG approved, I'll be at the river tomorrow....
Post by: rush1 on June 04, 2014, 06:32:02 AM
I would replace that valve and all that cracked fuel hose before you have major problems
Post by: el mojado on June 04, 2014, 07:28:04 AM
So it looks like with a valve like the OP is showing, when switching tanks , there is constant voltage holding it open? Hmm. I think I will be switching over to manual as well.
Post by: Ecm101 on June 04, 2014, 08:57:40 AM
It's for screwing on your transom and hooking a wire and three hoses to
Post by: Brad @ SCJB on June 04, 2014, 10:06:29 AM
im curious, why are you concerned with the constant voltage holding it open? just wire the switches power to the ignition power, so when the boat is off, the switch turns off.
Post by: el mojado on June 04, 2014, 10:08:19 AM
^ true
Post by: rush1 on June 04, 2014, 01:25:32 PM
They default to the top port so run the bottom port first in case it takes a dump that way you'll still have fuel to get back.
Post by: jetinator on June 05, 2014, 12:11:55 AM
Yep back in the day my brother had a dana jet and it had dual tanks without a selector just a tee. When we would run out of gas the one tank would still have a 1/4 tank of gas, usually tried to not get it that low without filling but in the rare occasions we did, we would use vise grips and pinch off the one tank.
