Classifieds => Engines / Engine Parts For Sale => Topic started by: zg2909 on June 26, 2012, 08:41:05 AM
Title: 525ci bbc short block
Post by: zg2909 on June 26, 2012, 08:41:05 AM
bc short block tall deck. the motor was built by YEOMAN RACING. link. www.yeomanraceengines.com (http://www.yeomanraceengines.com) It has a eagle 4340 forged steal crank ,eagle 4340 forged steal H beam rods, floating pins, je/srp forged pistons. 9.5to1 . $3495. for short block OBO CALL OR Text 417 559 0909
also have lot of other parts
dart s/r 360cc heads bare
comp cam ex marine hyd roller cam
comp cam r series roller lifters pn 887-16
comp cam beehive springs pn 26120-16
comp cam push rods pn 7964-16
comp cam beehive retainers pn 795-16
comp cam locks pn 611-16
comp cam seals pn 503-16
comp cams lash caps pn 621-16
comp cam guides pn 4806
comp cam cups
manley sd 2.300 valves pn 11854-8
manley sd 1.880 valves pn 11843-8
jesel shaft rockers
  and lots more
Title: Re: 525ci bbc short block
Post by: zg2909 on June 27, 2012, 07:10:32 AM
   I HAVE A SET OF HEAD'S Dart Early Design 360cc Intake Race Series 24° Aluminum Cylinder Heads (Pair). CNC Super/Mod port work in combustion chamber (119cc) and intake port match. 2.300 Intake Valve, 1.880 Exhaust Valve Exhaust Port raised .300" with Raised head bolt bosses to eliminate any flow restrictions Ductile Iron Valve Seats, Bronze Guides THE SAME HEADS ARE FOR SALE ON EBAY FOR $1600.00 the heads will need put together but i have every thing to do so. I ALSO HAVE COMP CAM RETO FIT LIFTERS  a HARDIN/COMP HYDRAULIC RETRO FIT ROLLER CAM DURATION ADVERTISED IN318 EX329 @.50 IN252 EX262  LIFT IS 612IN 612EX LOBE SEP. ANGLE 114. HAVE 10 QUART PAN  JESEL ROCKERS. IT JUST NEED PUT TOGETHER
