Tech Talk => Gelcoat / Paint / Fireberglass Repair => Topic started by: jamiemwedmore1234 on December 14, 2013, 07:12:32 PM
Had a seat problem no matter how tight they were fastened down the still we're loose the jack ass that re did my interior leveled my floor out did it over my old floor carpet and all so I ripped out everything and went back to the existing floor so new seat buckets were now needed And removed the railing so I patched up the holes got to get it ready for a paint job
Some more pics of before I started probably removed a 100 lbs of crap
Patching some holes where the rails were mounted and where the ventilation holes were
So I need some input from you fello boaters should I glass inn the seat buckets so they don't ever move or come out or rig it to be removable and I was tossen the ideal around of epoxy coating the hole inside of the boat instead of Capet what's your thought ???
I would glass them in JMO. As for the epoxy coat... DON'T! It will not last and will look like hell. It you are looking for color on the floor i would flow coat it. Prep the floor and get it nice and smooth. Then prep with 100 grit and spray it. Flow coat is a Half gel coat and half clear coat. If done right, it will be a walk away finish.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi216.photobucket.com%2Falbums%2Fcc168%2Fjyeager04%2Fe87b7ccc-785f-4e2d-9272-b24bbbd21cef_zpsd259a4f0.jpg&hash=802045aa1178d05f1a611a4abcabc67fcb425f98) (http://s216.photobucket.com/user/jyeager04/media/e87b7ccc-785f-4e2d-9272-b24bbbd21cef_zpsd259a4f0.jpg.html)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi216.photobucket.com%2Falbums%2Fcc168%2Fjyeager04%2Fnull_zpsc9e09d05.jpg&hash=fe6eae872180a567bd5f6ca5fcddb09f9a56cd45) (http://s216.photobucket.com/user/jyeager04/media/null_zpsc9e09d05.jpg.html)
That looks clean. Did you remove the center floor or is that the way it was
It's a tunnel hull, there is no floor really. If you take your time and make everything smooth and straight, you'll have a awesome looking floor.
Weekend after weekend all the holes are filled and almost ready for some primer 1 more weekend I hope
1st piece I painted so far trial run turned out pretty good I think
Looks great
Sent from my SCH-I545 using SoCal JetBoats mobile app
Scoop looks really good
What kind of paint is that
Sent from my DROID RAZR using SoCal Jet Boats mobile app
Good job that looks awesome!! We're did u get ur carpet
ppg is the brand fleet white is the color
thanx. What carpet ??
Is that a single stage?
Imron?
Imron?
yes sir
Got the boat primerd got rid of the non skid on the perimeter and all the holes from the railing cleats etc etc
Turned the garage into a paint booth with a shit load of plastic and a box of staples hopefully this help keep the dust off while it's drying the goal is to paint this weekend if weather permits
So painted today. First time painter think it was to cold to paint cause it looks like orange peal I'll take a better pic tomorrow with some natural lighting looks like a lot of color sanding now
Hey nothing a little wet sanding won't fix
Just curious, where did you get that wobble light lol?
got it from work don't know where they got it from throws out some good light tho
