what did you use to paint the stringers? just ordinary rattle can paint? that really cleans it up
what did you use to paint your pump? looks brandy new!
keep those pics coming!
Pull the engine again !!!look here bow tie boy, you post another pic of that, :P oh well you get it
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fwww.hotboatpics.com%2Fpics%2Fdata%2F500%2F16883Pict1918-med.jpg&hash=6aa252ba5da599d706d81006c5e851b35d3633c8)
those motor mounts are sweet. look nothing like mine.
that is what i am looking for. i like the cast aluminum mounts with the rubber mounts. the bad thing is that i would have to cut apart my new floor to get them installed. i think i am going to change the ujoint first and if that does not cut it this is the way i will go.
It doesn't look like you'd need to cut your floor at all for those cast aluminum mounts. But if other people are using the mounts similar to yours without any problems...
Engine removed again so I could drill the intake for the through bolts for the loader.
They make stringer washers to keep the bolts from getting "sucked in" I think you can even get powder coated ones to add to bling factor O0
Nice photos and it'll help me when I do the repairs while my engine is getting rebuilt. My bolts going through the stringers are carriage bolt that have been sucked up so far that they are almost buried in the wood. Those will get pulled, plugged and glassed over. Then I'll put aluminum backing plates so this won't happen again.In my opinion the best way to fix your problem would be to get some flat 1/4" thick by 4" wide and span it the length of the motor + maybe 4" past each side . Drill it and then use the stringer washers . Similar to a rail kit . It disributes the weight of the motor across a larger span on the stringer . Alot of times people fix shit with a band aid and here we are fixing a band aid . This all only assuming your stringers aren't rotten on the inside .
Do you have any good suggestions as to how to make sure I get any oil removed from the wood without replacing the stringers before I glass them in? Nice work! Greg
Great thread too Jim . Very informative and a great lesson . ;)
Here are a few more pics;
