Tech Talk => Gelcoat / Paint / Fireberglass Repair => Topic started by: LILDAWG1961 on May 10, 2011, 05:27:21 PM
Title: Multiple problems!!
Post by: LILDAWG1961 on May 10, 2011, 05:27:21 PM
The attached pics are of my 73 Kona project,motor is smoked but working on that,a friend has left me the boat and beings that I'm a newbie to fiberglass  I was hoping that the peeps on this board might be able to give me some help.Not sure of the terminology but one pic shows where an eye bolt was used in the front of the boat,and I would like to replace or repair with with the correct part and the next pic is a chip that looks like a lot of clear coat has been applied,it appears to be extremely thick so I was hoping someone might be able to identify and tell me if this is the original paint and color.
Thanks for the help.
Title: Re: Multiple problems!!
Post by: Your Mom on May 10, 2011, 05:32:09 PM
Looks like a couple layers of clear...How about a pic of the boat.  Might just want to run it as is till you can get a better hull.
Post by: Nordie on May 10, 2011, 06:39:45 PM
that there looks like alot of work
Post by: propless on May 11, 2011, 02:48:22 AM
 Why do I see wood by that eye bolt ? There should be no wood there.  Maybe your buddy stuck a wooden dowel in the other hole where the U bolt belongs.  Will be interesting to see just what that eye bolt is bolted to, dont see a nut on the outside just a bunch of sillycone.
 How is the rest of the boat, stringers, transom, etc, etc.  Finding a "repair" like that would make me dig carefully through the rest of the boat looking for other issues.
Post by: SuperJet on May 11, 2011, 07:39:02 PM
Hey Proppy my Sanger has a wood reinforcement where my bow eye goes through.. looks factory to me????
Post by: IRRebel on May 11, 2011, 08:02:28 PM
I would agree, but looking VERY closely at the pic, it would seem someone simply screwed an eye bolt into a, what, maybe modified 2x4 as a backing plate?
Whichever, a LOT of work ahead of ya fixing that! I'd start grinding on the INSIDE to see if a wood backer was factory or not, but either way, gonna end up with a 6x6 hole probably and a lot of fiberglass work ahead of ya!  ;)
Just my .02, IF it had wood in there to begin with, I'd eliminate that and lay it up a few layers heavier with a 4x4 or so SS plate as backup.....
Post by: Nordie on May 11, 2011, 09:23:30 PM
that is definately a eye bolt, and not a bow eye, it used to have a bow eye, and it somehow got ripped out, not even seeing that whole boat, but i feel it would scare the shit out of me...i would seriously consider buying a new hull unless you are dead set on alot of hard work, following some safety issues like that bow (im gonna call it chinga dera) eye
Post by: propless on May 12, 2011, 12:07:30 AM
 Yea, your right about the wood reinforcement inside the hull my Brendella has that too, but you wouldnt see it sticking out flush with the outside of the hull like that.  Still looks like someone stuck a wooden dowel in the second hole for the original U bolt to me.  Then smeared it with sillycone.
 Climb inside there and lets see what the inside looks like LILDAWG1961.
Post by: LILDAWG1961 on May 12, 2011, 05:04:14 PM
Ok I understand using a U-bolt but how do you secure it,somebody mentioned crawling up inside,I haven't looked real hard but is that possible? I'm not a small individual but cant imagine getting up there,besides that theres a fuel tank in the front.
Starting to lean towards abandoning the ship..before she sails.
Post by: SuperJet on May 12, 2011, 09:14:11 PM
yes you or someone smaller will have to crawl up under the bow and bolt the bow eye in and seal it with marine silicone...
Post by: Nordie on May 12, 2011, 10:06:46 PM
i would have abandoned ship a long time ago just looking at the bottom of that boat...i really hate to sound like debby downer, but that poor boat is hammered! im not saying that it cant be fixed, but how far are you willing to take this boat? If your willing to bring this thing back up and use it, then all the power to you, but if you want to half ass it then i really hope you dont plan on putting your family in it!
