Tech Talk => Gelcoat / Paint / Fireberglass Repair => Topic started by: kwood on October 03, 2011, 02:15:29 PM
i just picked up a 1976 specta and the trailer need a fresh coat of paint, can i use car paint? or is there a type of paint i should use?
Check into having it powder coated. Much more durable and around the same price as having it painted.
yes use auto paint. you are going to want to use a really good primer. like a dp40 or 90. and a really good quality paint . so you wont have to do it again. good luck!
If you paint it white, the rust streaks will show easily down the road. I painted my old boat trailer about ten years ago. I did it at home and it would've turned out to be a good job except, Zieman, who sold me the paint, reducer and hardener... Sold me paint, reducer and another can of reducer with hardener labeled on it. It never cured and I ended up just buying a new trailer. I was 17 years old and didn't know a sneeze from a wet fart so I didn't question it when I was mixing :banghead:
Ka0tyk if your going through so much trouble to bedline certain areas, why not just do the whole trailer? Because I'm thinking like 3/4 of it needs either road or grip. Just wondering because I need to redo mine too. And I'm thinking of just bedlining the whole thing.
Sent while on the run, or sitting at work bored
ok this is just an oppion but dont put bedliner material on your trailer! it may look good for a LITTLE WHILE ! but it wont last. and then you will be scraping it off. and trust me it does not come off easy. dont do it.
I WAS THINKING OF LINEX ING THE STEPS ON THE TRAILER THEN PAINTING. THE SPARY LINER COMPANIES (RHINO LINER, LINEX, ETC..)ARE THE ONLY I THINK I WOULD PUT ON THERE, CAUSE I HAVE NOT SEEN A ROLL ON THAT LASTS. WELL SEE, I AM WAIT TILL NOV. TO START IT. IS A WIRE BRUSH THE BEST QUICKIEST TO TAKE OFF THE PAINT? OR SANDING? CAUSE BLASHING THAT MUCH AREA SOUNDS EXPENSIVE.
My trailer is sanded....think I am gonna liner mine. In the past I have used a product called durabak....comes in different colors. I think this time I am gonna try duplicolor....they have both a roll/brush on product...as well as a spray. I am hoping the appearance/ texture is similar on both. ....that way I can roll the large areas...and spray the tight spots.
And I think the resto bed liner (it comes in a rattle can) works pretty good. Seen it on a few different applications, I just don't want something that is going to cost a grip and only look real good for a few years.
HOW AROUND IN POWER COAT OF THAT SIZE?
sorry work programs uses cals lock and i forget to take it off some times :banghead:
Anyone know how much it might be to blast and powder? I don't think there will be many actual holes, just spots of crap...
