Tech Talk => Jet Pumps => Topic started by: SWIFTMIKE on June 26, 2014, 06:29:47 PM
Title: Advice on pump mods
Post by: SWIFTMIKE on June 26, 2014, 06:29:47 PM
Just picked up a spectra 18 and took it out for the first run last weekend.  Just looking for advice on what the trick setup on the pump on these might be.  Right now I have a BBC 454 that is mostly stock.  Pump is a Berk JC with a intake loader and place diverter.  Boat runs good to about 4k then it seems like the pump cavitates and I can't get anymore mph out of it but I have plenty of rpm left.
Title: Re: Advice on pump mods
Post by: GT Jets on June 26, 2014, 07:22:44 PM
Without the advantage of touch taste, smell. Sounds like the loader is too deep.... Got pictures?
Post by: SWIFTMIKE on June 26, 2014, 08:06:03 PM
Not sure what angle you want but here us from the back
Post by: GT Jets on June 26, 2014, 08:20:28 PM
Well I got two potential problems I see...
First, that bent to hell keel fin needs to be straightened or removed, I suspect it is causing havoc with the water entering the pump.
Second, the leading edge of the loader ramps should be within 1/8" (above or below) the keel line at it's lift point on the vee, meaning the loader needs to be trimmed so that nothing hangs below the keel more than 1/8", it will likely need to be cut at an angle to get the most out of it.
Otherwise, if the pump is snug and there are no chunks missing from the impeller, you should be fine.
Post by: GT Jets on June 26, 2014, 08:21:35 PM
BTW, what loader is that?
Also, you should not smoke.... Bad for you..  ;)
Post by: SWIFTMIKE on June 26, 2014, 08:30:59 PM
Lmao...I knew someone was going to say something about the keel fin!  I appreciate the advice!  I will work on tweaking the keel fin and taking a look at how deep the loader is set.  I'm not sure what loader it is.....is there an easy way to tell?
Post by: Riverlife_ on June 26, 2014, 08:33:14 PM
It looks like a sport loader
Post by: Riverlife_ on June 26, 2014, 08:34:37 PM
Like this?
Post by: Your Mom on June 26, 2014, 08:37:07 PM
I have a spectra 18 bull nose... have had it now since 2004. Got rid of the keel fin, added bolt on ride plate/shoe 3 degree up, aggresor 9 vane/stuffer, pre loader, straight snoot/4 degree pin and diverter. I still use a rock grate. I get 5100-5200 with a 466 bbf. Rides the best I've owned since these mods.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi897.photobucket.com%2Falbums%2Fac178%2F2ndlight%2Fym931_zps590de07a.jpg&hash=7ea00e9808d338d999992220bf0691e1c6ed0045)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi897.photobucket.com%2Falbums%2Fac178%2F2ndlight%2Fym01_zps33936829.jpg&hash=a813d0f5c2e90219f7bea57e05c10d6f59ccc879)
Post by: SWIFTMIKE on June 26, 2014, 09:10:38 PM
That's a lot of work done to that pump! Boat looks beautiful though! Nice to get input from someone with the same boat!  Here's a pic of mine from last weekend.
Post by: SWIFTMIKE on June 26, 2014, 09:12:58 PM
Like this?
Yup that looks like the one! Thank you
Post by: GT Jets on June 26, 2014, 09:18:18 PM
Put the stock rock grate back in.. JMHO.
Post by: SWIFTMIKE on June 26, 2014, 09:27:13 PM
OK I will give it a shot this weekend thank you
Post by: Your Mom on June 27, 2014, 05:43:34 AM
Here's a link to my over hall last year...
http://www.socaljetboats.com/projects/new-floor-install/ (http://www.socaljetboats.com/projects/new-floor-install/)
