Tech Talk => Jet Pumps => Topic started by: cbuda65 on June 24, 2009, 03:03:42 PM
Title: help!!!!
Post by: cbuda65 on June 24, 2009, 03:03:42 PM
well i took my boat out for the first time its a 78 kachina w a bbf460 the boat ran great all weekend and the last day i took it out i wasnt sucking no water in through the jet just seeing what the possible reasons of why this happened
Title: Re: help!!!!
Post by: OC2Vegas on June 24, 2009, 03:12:29 PM
You either broke your pump shaft or you need to lay up under the boat and see what you sucked up in there
Title: Re: help!!!!
Post by: IRRebel on June 24, 2009, 03:28:51 PM
Coulda broke the drive coupling or the bolts to the crank too I suppose. My Biesemeyer 'seemed' to do that a couple of times when it was just a rock jamming the reverse bucket about 3/4 closed. Also happened on the Moo on Saturday when the bolt fell outta the reverse bucket cable, wouldn't move, the Jet would open the bucket just enough under throttle to hold it in a neutral position. Thought for sure I'd busted something important! I'd check out your reverse bucket and control lever, etc,  just to be sure.
Title: Re: help!!!!
Post by: 2savage4you on June 24, 2009, 04:26:07 PM
The day i tried to get my boat wet, i had the same problem...
It was just an air pocket in the bowl, i got no water to the engine and no thrust from the pump (at Idle) i didnt even try to take her out..........by the time i realized i wasn't getting water  the engine was already at 190 :mad:
Title: Re: help!!!!
Post by: cbuda65 on June 24, 2009, 05:05:43 PM
thank you guys it does seem like it was a air pocket cause when i shut it down and started it again it was ok after a bit but my temp was rising and it started to worry me a bit but i will check all that out
Title: Re: help!!!!
Post by: cbuda65 on June 24, 2009, 05:07:29 PM
does that happen very often the air pocket?
Title: Re: help!!!!
Post by: 2savage4you on June 24, 2009, 05:08:09 PM
Do you have a droop ?
Title: Re: help!!!!
Post by: cbuda65 on June 24, 2009, 05:50:08 PM
yes it does have a droop
Title: Re: help!!!!
Post by: beerjet on June 24, 2009, 05:56:00 PM
Droops are notorious for causing this.
Title: Re: help!!!!
Post by: jet boat performance on June 24, 2009, 08:51:01 PM
The guys are right (re Droops) you need a "bleeder) (little brass deal in the middle of the bowl) mine are under 25 bucks , simple to install Tom
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi147.photobucket.com%2Falbums%2Fr319%2Fjetboatperformance%2Fmach1%2FDSC04654.jpg&hash=182686e7e691c5b8577cfa4178fd26508e0cb073)
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi147.photobucket.com%2Falbums%2Fr319%2Fjetboatperformance%2Fmach1%2FDSC04192.jpg&hash=87db132156237454df698bac137254f9b5082d12)
