Tech Talk => Jet Pumps => Topic started by: fastnlight on May 23, 2013, 06:05:34 AM
Title: Oil Leak from bowl?
Post by: fastnlight on May 23, 2013, 06:05:34 AM
Newb to jets.  Just had a new impeller and wear ring installed.  Started boat up in driveway.  Ran for about 30 to 40 seconds with hose and oil started dripping from the pin that the steering pivot on at the bottom of the droop.  Doesn't seem right? Are my seals shot? Thanks.
Here is a pic of the pin I am talking about.
Title: Re: Oil Leak from bowl?
Post by: fastnlight on May 23, 2013, 06:18:20 AM
I cut and paisted this question and answer from the Berkeley website.  It says to "run water into the pump through the nozzle while running on the trailer".  I didn't do this.  Do you guys do this?
Q: Can I runmy pump while the boat is on thetrailer?
A: Running the Berkeley out of thewater:
A Berkeley pump can be run out ofthe water as it has a greasedthrust bearing and lubricated tailshaft bushings. The impeller doesnot touch the wear ring, but dueto the fact that the bottom of thepump is open during trailering theboat, it is best to run water intothe pump through the nozzle whilerunning on the trailer. The onlyissues with running out of thewater is that after about 15 to 20minutes the bowl seal can get hotfrom lack of cooling and causeseal damage. The packing gland mayhave to be re-tightened when theboat is used the next time aswell.
Post by: Your Mom on May 23, 2013, 06:23:05 AM
You might have blew the seal forward when starting it up on the trailer. If thats a G bowl you can take it off slide seal back on then take a punch to the outer housing area of the seal. Tap a couple spots in the outer rim to pinch the seal slightly from popping out so easy.
Post by: fastnlight on May 23, 2013, 06:30:26 AM
Thanks, Its actually an E, converted to a split bowl.  Would it be the same as a G?
Post by: mash on it on May 23, 2013, 06:50:12 AM
An 'E' pump would be even easier to pull, no transom adapter to pull, and fix/replace that rear seal.
As far as running on the trailer, the impeller is .012 away from the wear ring, too close to run on the trailer in my opinion. After I rebuilt mine, I greased the wear ring to fire it for 10-15 seconds, then off to the lake. (after ~200 hours, W/R to impeller was .035"+ per side) I've also seen how much crap that the pump stirs up at the launch ramp, is that any better than a dry or on the trailer start? I think so...
Post by: Your Mom on May 23, 2013, 07:29:02 AM
This is a pic of a bowl I'm selling and has the rim around the seal center tapped a few times for the same reason...kept it in the whole time I used it. I also ran grease through it instead of oil.
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi897.photobucket.com%2Falbums%2Fac178%2F2ndlight%2Fjbp6_zps9bd910ca.jpg&hash=c39bd80a9f796945adcbf609c59007aff3f33b85)
Post by: fastnlight on May 23, 2013, 07:34:49 AM
Ok.  Well it looks like I'm going to take it apart.  Do I need a new gasket when I put it back together or can I reuse the old one?
Post by: Your Mom on May 23, 2013, 07:51:07 AM
If your careful and don't damage it like the pic in mine. Run some oil/grease around shaft before putting it back on. If your seal just popped forward to impeller nut...slide it off carefully an inspect for damage.
Post by: fastnlight on May 23, 2013, 08:05:18 AM
Just got the bolts off.  Is there a trick to breaking the seal?  Its on there really good.
Post by: mash on it on May 23, 2013, 08:34:56 AM
No need to take the droop/steering adapter off, just the 1/2" bolts @ the suction housing to bowl, to get to that seal
Post by: fastnlight on May 23, 2013, 08:46:09 AM
OK  I just looked at a Berkeley diagram.  I see where it is now (I think).  For some reason I was visualizing it at the rear of the bowl.
Post by: mash on it on May 23, 2013, 09:05:40 AM
Kinda the rear of the bowl, from the impeller side, like 'Your Moms' pic above
Post by: fastnlight on May 23, 2013, 09:55:28 AM
Here is a pic of the seal.  It appears to be in good condition.  It does seem a little offset though.  Is it supposed to sit flush against the bushing?  There is a gap as you can see.
Post by: fastnlight on May 23, 2013, 10:49:20 AM
The seal wasn't loose at all.  Its in there real tight.  I heard back from the guy that did the impeller change out and he seemed to think it might just be residual oil from the reinstall.
Post by: Your Mom on May 23, 2013, 10:57:40 AM
Where was the seal when you took it off... that gap is normal. If the seal was still in place it might be bad or like you said residual. Was there an oil trail coming from it? Tape the hole up where the seal is then fill the bowl with oil. Look for leak
Post by: fastnlight on May 23, 2013, 11:46:07 AM
The seal wasn't off at all.  It was just like you see in the picture.  I couldn't see an oil trail.  I've put it all back together, filled it with oil and watching it for a while.  I think I'm going to just water test it and keep an eye on the oil level.    I'm hoping it was residual.  I was also told it could be a hairline crack or hole in the bowl.  A usual I supposed to use the boat all weekend, but I was told to just keep an eye on the oil level.
Post by: Your Mom on May 23, 2013, 04:41:07 PM
It will leak from time to time regardless...you will see water in there as well so remove both plugs and fill one side till it flows out the other done. I thought you might have a crack as well thats why I asked to tape it and fill. I have a split bowl for sale in you need.
Post by: fastnlight on May 23, 2013, 07:07:03 PM
Good to know. Thanks for your help!
