Tech Talk => Jet Pumps => Topic started by: Deadend on May 01, 2012, 12:04:54 AM
Why is it bad on a pump to run it out of water? I've done in the past and get grief for it!!! Ive never done it for very long as my motor runs on gas not alcohol!! But I've never had any problems....
I think its bc the jet has thrust bearings that can go bad if there isnt pressure on them. I am not sure so i am sure someone else will chime in
there is about .030 clearance between the impellor and wear ring and when the contact well you get the idea
don't do it.
I fire mine up now and then for small adjustments and run water through it. I dont let it run long and its been fine for years of doing this.
