Tech Talk => Jet Pumps => Topic started by: hotrod56cars on January 16, 2008, 09:43:16 AM
Title: What is this pump, exactly?
Post by: hotrod56cars on January 16, 2008, 09:43:16 AM
[attachimg=#]
This pump has a clean out very similar to a Jacuzzi, it has no ID tag on it, the bowl looks like a Dominator split bowl, and it says bayjet (duh) on the transom cover. WTF?
Title: Re: What is this pump, exactly?
Post by: DOZZR on January 16, 2008, 09:50:08 AM
 ;D Where do you find all this chit lmao. ;D
Post by: 2savage4you on January 16, 2008, 09:51:20 AM
Are you kidding :o
He's Sanford ;D
2sav >:D
Post by: Ema Non-Performance Marine - BANNED on January 16, 2008, 09:52:52 AM
They are just one of the many copies that were done back in the day. Everybody tried to get into the game. And only a few lasted.
Post by: 2savage4you on January 16, 2008, 09:58:19 AM
Im sure Tom @ JBP  can give you more info on this than we can ;)
2sav
Post by: Brad @ SCJB on January 16, 2008, 10:00:11 AM
its a berk clone with the same insides as a berk.
Post by: hotrod56cars on January 16, 2008, 10:00:57 AM
Craigslist   ;D
A copy of several different brands apparently  :P
2sav
Yea, waiting for replies from some more experts...  ;)
Post by: Josh@JBP on January 16, 2008, 10:50:14 AM
Very similar to a Berkeley more or less the early 12JA, some of the parts are inerchangable I believe the shafts are the same (2" longer version), the bowl will bolt up, Impellers also...not sure on wear ring.  Uses clipper seal instead of packings.  4 bolts need to be redrilled to use a Berkeley on the Bayjet intake (theres also some history between Bay Jet and Roy Miersch towards the end, But I don't remember the specifics, perhaps my Dad will remember).  The nozzle adapter is much worse than even the early Dominators, Same bolt pattern.  The bowls have extremely flat inlet vains, and water lubed glacier bearings.
Post by: Josh@JBP on January 16, 2008, 10:56:40 AM
The nozzle adapter is much worse than even the early Dominators...
(https://forum.socaljetboats.com/proxy.php?request=http%3A%2F%2Fi147.photobucket.com%2Falbums%2Fr319%2Fjetboatperformance%2Fjosh%2FDSCF0152.jpg&hash=16da4f727566ba8ef78af99a7b1e31d5797e6cac)
Post by: jim brock on January 16, 2008, 11:27:09 AM
i have 2 or 3 on the shelf if you need parts, Jim
