Tech Talk => Jet Pumps => Topic started by: mike drdla on September 01, 2011, 04:01:56 PM
Title: What size shoe does my little girl wear?
Post by: mike drdla on September 01, 2011, 04:01:56 PM
Hey guys as you all know there's a wealth of knowledge on this site. I've tried studying all the answered questions, but the only thing I can come up with is that everything is trial and error.  I was hoping that a could get some info on where to start with my pump setup. I have a eliminator scorpion with the daytona bottom with a berk already installed. The suction is about 1 1/2 lower than the sides of the boat, the pump was set back it has no shoe or ride plate. I'm installing a 380 lb V8 with only about 400 hp. I understand these run wet and I'm not really trying to go 100mph.  I'm afraid to start buying the wrong parts because of lack of knowledge or because it"s a good deal. Most things are fairly easy to change but I would rather get in the ball park from the start. So basically I'm looking for some info on shoe thickness to start, should i run a ride plate, droop snoot, what loader grate. There is also a possibility of another 100 hp down the road with a huffer but thats probably as hot as i will go. Any info would be greatly appreciated.
Title: Re: What size shoe does my little girl wear?
Post by: wizard612 on September 19, 2011, 05:18:36 PM
First I would post your question to Greg Shoemaker on the Performance Boat web site.  I'm not familiar with the scorpion, if it's the one I'm thinking of it had a bad shut down issue.  That being said I'll tell you what I did with my Daytona back in 78.  Loader, Yes, mine was a center blocker depth I can't remember. Rideplate and shoe, yes, I used about a 1" shoe with a 1" back cut leaving the front edge about stock.  I had a flat keel boat too.  Now the reason we set it up that way was I ran SKi-Jet II class which was .030 over 454 with single 750 dp. Eliminators back then were fairly heavy.  We set the boat up with a lot of lift becauce we were down in HP compared to the drag boat guys. Be warned My boat was excellent in shut down and turned on a dime ( circle boat racer) It porposed like crazy at low speeds due the loader, shoe and ride plate. We also did not have a set back pump and we moved the motor forward about a foot using a Lenco drive line.  Be sure to check with Greg he will give you the best place to start with your hull and equipment.
Post by: 19ftCheyenne on September 19, 2011, 05:53:11 PM
is this the orange green and yellow scorpion? damnit i wanted to buy that boat haha! u beat me to it!!  :banghead:
Post by: Willow Wog on September 19, 2011, 06:20:03 PM
Hit up Nick, madskillz on the board he has a scorpion with alot of bottom mods. He has his set-up damn near perfect.
Sent from my Droid, sitting at work wishing I was at the river..
Post by: jet boat performance on September 20, 2011, 07:13:03 PM
Hey guys as you all know there's a wealth of knowledge on this site. I've tried studying all the answered questions, but the only thing I can come up with is that everything is trial and error.  I was hoping that a could get some info on where to start with my pump setup. I have a eliminator scorpion with the daytona bottom with a berk already installed.   The suction is about 1 1/2 lower than the sides of the boat  , the pump was set back it has no shoe or ride plate. I'm installing a 380 lb V8 with only about 400 hp. I understand these run wet and I'm not really trying to go 100mph.  I'm afraid to start buying the wrong parts because of lack of knowledge or because it"s a good deal. Most things are fairly easy to change but I would rather get in the ball park from the start. So basically I'm looking for some info on shoe thickness to start, should i run a ride plate, droop snoot, what loader grate. There is also a possibility of another 100 hp down the road with a huffer but thats probably as hot as i will go. Any info would be greatly appreciated.
[/quote
Several things , Photos and more info would be helpfull and re the suction ? are you maybe meaning the intake is this jet intake really set in and setback and not machined for a ride plate and shoe or is it missing them? Tom
