Tech Talk => Projects => Topic started by: bluegoose95401 on February 28, 2011, 08:36:36 PM
hello every one
i just got this boat from a friend. it is in peces as he was took it apart to restore it and never got to putting it togeter again. first i would like to kno if any one could tell me what kind of boat it is all it says on the reg is "the boat shop" it has a ford 460 with bassett wetstacks, a berkley pump and it is a 1979 model that is all that i know about it and having trouble looking for parts for it. second all the cooling lines are gone as well as the thermostat and housing i was woundering were and what kind of thermostat housing to get for it. third i also need some pics of how to run the cooling lines from were ever it starts through to the end where ever that may be. any help or input would be great im am really looking forward to getting this puppy goin and i need all the help i can get
T stat housing on most Fords I've seen in a jet boat is a flat piece of aluminum. I happen to have a few of the weird ones that must have been used for logs here. But the flat one is usually drilled and tapped and the temp sending unit threaded in there. You can make one of those easily enough. Post up some pics and we can plumb it for ya! ;)
Are you talking headers or OT pipes? WTF is a "wetstack"? :screwy:
HIN search http://www.uscgboating.org/recalls/mic1.aspx (http://www.uscgboating.org/recalls/mic1.aspx)
Your lines will depend if you have logs or headers...
the guy i got it from kept calling them wet stacks but more resurch i do i found them to be headers with water injection.
post up some pics and these guys will break it all down for you.
