Tech Talk => Projects => Topic started by: Ban one on September 25, 2012, 02:10:58 PM
Title: Removing chrome from pump bowl
Post by: Ban one on September 25, 2012, 02:10:58 PM
Hello, been a regular reader here for some time, but am looking for any advice/experience in removing chrome.  My pump bowl was chromed at one time, but age hasn't been good to it and it is starting to flake off in several areas, but only about the size of a pencil so I want to remove it all to refinish with paint to match the hull.  Anybody had any success in this area?  I have tried to get a thin blade under the edge around some of the bare areas, but the chrome doesn't seem to want to flake off.  I'm open to any suggestions.
Title: Re: Removing chrome from pump bowl
Post by: mobboss on September 25, 2012, 02:46:57 PM
chrome is removed by dipping it in an acid bath!  all other ways will probable mar your bowl.
Post by: Ban one on September 25, 2012, 06:47:07 PM
Wow, thanks for the fast replies. I was afraid someone was going to tell me I'd have to do it manually but both give me some hope of an easier way to remove it. The chrome shop or acid bath sounds alot more promising. Mobboss, you talk about dipping it. Is this something I can do, or the shop do for me?  If I can do it would I use muratic acid?
Post by: mobboss on September 25, 2012, 07:21:01 PM
yes you can not really sure i would though. also not sure which acid it is. then theres the what to do with all that used acid??? which now has really bad stuff in it.  there should be  couple platers in your area. call them.
Post by: 5150whiteboy on September 25, 2012, 07:51:13 PM
It's actually fairly cheep to have a shop do it usually takes them 1/2 a day I paid El Monte playing 20 bucks to remove chrome off both my exhaust pipes for my quad
Sent from my iPhone using Tapatalk
Post by: Ban one on September 25, 2012, 08:54:27 PM
Thanks for the great info, I hadn't thought about the disposal after the fact. Not sure how close the nearest shop is, but will be looking for one tomorrow. Hopefully I can get it done for a reasonable price. Thanks again
