Discussion => The No Wake Zone => Topic started by: BIG JOHNSON on November 12, 2011, 02:18:06 AM
Can I run my water inlet line up near drivers seat to put my gate valve on to control water temp easier?
Going that far with convenience, can I run fuel line to my left hand to switch tanks?
...just thought I'd ask the audience
Chevy or ford.... If you have a ford just run it wide open. Chevy and olds should be regulated more for flow than temp.
http://www.cpperformance.com/c-502-fuel-valves.aspx (http://www.cpperformance.com/c-502-fuel-valves.aspx)
yeah, you can run your water up to a valve at the seat, but why would you want to do that with logs. Ideally you would do it to control the water going through over transoms (shut it off at idle) but with logs you just set it and forget it.
about the fuel valve, just get an electric one. the one linked by yourmom is a bit pricey and complex but gets the job done. I have a simple one that appears to be out of a car/rv and it works great. not sure what its from though.
You can buy universalr suel selector valves from your local auto parts store. They are about 20 to 30 bucks and all it takes to hook up is a ground and hot wire. add a switch on your dash run the wire and hook up the fuel lines and you are good to go.
Gate valve is figured out. I got water temp to be at 130-140 underway but at idle it will reach 170.. What's the ideal temp to run at?
Gonna check out Napa's product book for an electric fuel line selector when I go stock up on wix filters. I think my boat had one at one time cause there's an abandoned switch and looks like something was mounted on the transom where the fuel lines meet.
When I bought it the lines just T'd and the tanks drained simultaneously.. kind of. I didn't like the idea of one tank drying out and it not being able to draw from the other, so I put a manual selector on it. It's not bad but a pita to crawl into engine compartment to keep an even keel.
Good points guys
