Discussion => The No Wake Zone => Topic started by: Bebo on July 08, 2012, 07:26:48 PM
Title: wiring problem
Post by: Bebo on July 08, 2012, 07:26:48 PM
Hey guys whats going on. I have a problem with all the wiring under my dash. Not the ones from the ignition but from my stereo speakers and amp thats under there. What would be the best way to tuck them up..under the dash is only fiberglass so cant glue anything and i want it to be easy and simple if possible. Thanks guys all feedback will help
                      Bebo
Title: Re: wiring problem
Post by: mobboss on July 08, 2012, 08:02:18 PM
well if you have time and somethin really trick! run them all in clear tubing.then use gorilla glue to hold the tubing up.
Post by: Bebo on July 16, 2012, 01:20:52 PM
yeah sorry about the typo..i meant i cant screw anything becuase its not the dash its the whole front of the boat the underside so if i did screw something itd go right through my deck. I dont think that much tubing either would be clean. I just want couple points where the wiring is held up and not sagging.. I was thinking velcro straps. glue one end tot eh deck then velcro the wire up. That way i can take the velcro off if i need to get to the wires for some reason.. Anyone think this isnt a good idea?
Post by: Bebo on July 17, 2012, 11:39:35 AM
that might not be a bad idea. as long as they stick well itl work..If not im sure some super glue wont hurt holding them up ;)
