Tech Talk => Trailers => Topic started by: BIG JOHNSON on March 21, 2012, 10:24:28 PM
Title: Wheel bearing grease
Post by: BIG JOHNSON on March 21, 2012, 10:24:28 PM
Bought the boat this past summer and have yet to grease the bearing buddies. Don't know what kind of grease goes in? It's green, and I'm gonna guess its similar to the green tube of grease I was given by mcclure to grease the pump bearing... Would I be correct in that assumption or should I call previous owner and get the skinny on it before I leave to Parker?
Sent from my ADR6400L using Tapatalk
Title: Re: Wheel bearing grease
Post by: crewchief22 on March 21, 2012, 10:49:17 PM
Pull off one of the bearing buddies and compare the grease you have to what's in the cap, if it appears to be the same use it.
Post by: GT Jets on March 21, 2012, 11:11:58 PM
In all honesty, color don't mean a damn thing..........
I recommend two different lubes that will both mix fairly well with virtually anything....
Aqualube   http://www.aqualubeky.com/grease.html (http://www.aqualubeky.com/grease.html)   , this sticky messy shit will mix, but hope and pray you never have a Buddy or a seal take a poop, you be cleaning that crap up for a month... :screwy:
Any NLGI 2 grease using lithium as a base. The synthetic stuff seems be mix with anything...I only know this from using tons of different greases and word of mouth (nothing from a lab)...
It's sort of like engine oil. Your better off putting the wrong oil in than nothing at all.... ;) You should really be replacing the grease seals and cleaning and inspecting the bearings for wear every couple of years. Having lost a wheel bearing in the middle of BFE at three in the morning is all that had to happen for me to do it at the beginning of each season.  :thumbdown: :thumbdown:
Post by: BIG JOHNSON on March 21, 2012, 11:22:25 PM
Note to self: bring a ratchet strap to pick up and cary a dead sided axle.
Gonna use the synthetic waterproof grease MPD gave me and put new bearings in when I come back for peace of mind... Now that the majority of fun is behind me.
Post by: mash on it on March 22, 2012, 07:43:13 AM
I used to grease the hubs EVERY trip from Big Bear to the river, and kept an eye on hub temps, never had a bearing failure. Now, being 18 miles from the river, its twice a year when going to willow beach. Ratchet strap or a block of wood is always a good idea.
Title: Re: Re: Wheel bearing grease
Post by: BIG JOHNSON on March 22, 2012, 11:54:21 AM
when we leave for the lake we always stop at a grocery store off the 10 and i ALWAYS feel the hubs to make sure before i start driving out in the middle of nowhere.
Good point, I'm sure my disc brakes get the hubs hotter than most.
Post by: farmergord on March 22, 2012, 12:04:45 PM
be careful of overgreasing if you have brakes.its easy to force grease out the back past the seal then when you drive it gets all over everything and ruins the brake pads
Post by: BIG JOHNSON on March 22, 2012, 12:56:45 PM
Yeah I've had Exxon Valdez happen all over the side of my old boat and every other car on the fwy once before. I only pump grease til I see the spring loaded cap start to move. The excess does nothing anyway.
Post by: GregS on January 08, 2013, 06:37:30 PM
For what it's worth; Use marine grease because it has cellulose in it, & will not melt & "fling" like all others. I always used the best stuff I could find.....& ALWAYS had a freaking mess on the wheels. Doh!
